查看: 1236|回复: 6
[求助]:版主, 不能 open 下载的Microstation 3d 学习资料 (英语版)
发表于 2002-11-27 00:12:29 | 显示全部楼层 |阅读模式
版主,  用 密码 xdsoft.126.com不能 open 下载的Microstation 3d 学习资料 (英语版), Thank you!
发表于 2002-11-27 00:36:29 | 显示全部楼层
Re: [求助]:版主, 不能 open 下载的Microstation 3d 学习资料 (英语版)
最初由 xiaogengxu 发布
[B]版主,  用 密码 xdsoft.126.com不能 open 下载的Microstation 3d 学习资料 (英语版), Thank you! [/B]
是在图纸中心下载的吗?还是论坛上?
不应该有密码的。
 楼主| 发表于 2002-11-27 00:42:00 | 显示全部楼层
是在图纸中心下载.
I'm sorry I have to explain it in English 'ause I'm a little in rush.
I load the document with my local harddisk, When I unpack it, the system remind me of input number ID, then I input xdsoft.126.com, it doesn't work.That's it.
发表于 2002-11-27 00:44:16 | 显示全部楼层
最初由 xiaogengxu 发布
[B]是在图纸中心下载.
I load the document with my local harddisk, When I unpack it, the system remind me of input number ID, then I ... [/B]
是提示你输入密码的框?不是CRC出错的框?
如果是需要密码,是花零斑竹传的吧,他来让他回复。
 楼主| 发表于 2002-11-27 01:00:37 | 显示全部楼层
I don't know what kind of frame it is.It's a small frame, like the below,
                       e3d2[1].part1.rar                    <------------- it's title
                       Number ID :0
                       H:\e3d2[1].part1.r00              <-------------This lilne is highlight
                       OK            Cancel
No problem I will wait for the answer after a while.
Thank for your help.
发表于 2002-11-27 01:16:42 | 显示全部楼层
最初由 xiaogengxu 发布
[B]是提示你输入密码的框?不是CRC出错的框?
                       e3d2[1].part1.rar                    <------------- it's ti... [/B]
截个图片到论坛来吧
 楼主| 发表于 2002-11-27 02:03:41 | 显示全部楼层
Sorry I don't know how to 截个图.
XD, could you do me a favor? You would make a try to load it, if no problem, I believe it 's my problem.
Appriciate you.
GMT+8, 2026-11-22 10:33 , Processed in 0.373080 second(s), 8 queries , Gzip On, File On.
