查看: 691|回复: 1
[ARX程序]:如何改变对话框的颜色?望高手赐教
发表于 2004-6-5 23:40:03 | 显示全部楼层 |阅读模式
我用ARX 开发cad2000,做了几个对话框,感觉颜色都是一种,很单调的,谨想各位高手讨教
发表于 2004-6-7 20:38:06 | 显示全部楼层
Ref. below, please:
  1. [COLOR=Blue]SetClassLong   [/COLOR]
  2. The SetClassLong function replaces the specified 32-bit (long) value at
  3. the specified offset into the extra class memory or the WNDCLASS
  4. structure for the class to which the specified window belongs.
  5. DWORD SetClassLong( HWND hWnd,
  6. // handle of window
  7. int nIndex,
  8. // index of value to change
  9. LONG dwNewLong
  10. // new value
  11. );
  12.
  13. Parameters
  14. hWnd
  15. Identifies the window and, indirectly, the class to which the window belongs.
  16. nIndex
  17. Specifies the 32-bit value to replace. To set a 32-bit value in the extra
  18. class memory, specify the positive, zero-based byte offset of the value to
  19. be set. Valid values are in the range zero through the number of bytes of
  20. extra class memory, minus four; for example, if you specified 12 or more
  21. bytes of extra class memory, a value of 8 would be an index to the third
  22. 32-bit integer. To set any other value from the WNDCLASS structure,
  23. specify one of the following values: Value
  24. Action
  25. GCL_CBCLSEXTRA
  26. Sets the size, in bytes, of the extra memory associated with the class.
  27. Setting this value does not change the number of extra bytes already allocated.
  28. GCL_CBWNDEXTRA
  29. Sets the size, in bytes, of the extra window memory associated with each
  30. window in the class. Setting this value does not change the number of
  31. extra bytes already allocated. For information on how to access this
  32. memory, see SetWindowLong and SetWindowWord.
  33. [COLOR=Red]
  34. GCL_HBRBACKGROUND
  35. Replaces the handle of the background brush associated with the class.   //use it!
  36. [/COLOR]
  37. GCL_HCURSOR
  38. Replaces the handle of the cursor associated with the class.
  39. GCL_HICON
  40. Replaces the handle of the icon associated with the class.
  41. GCL_HMODULE
  42. Replaces the handle of the module that registered the class.
  43. GCL_MENUNAME
  44. Replaces the address of the menu name string. The string identifies the
  45. menu resource associated with the class.
  46. GCL_STYLE
  47. Replaces the window-class style bits.
  48. GCL_WNDPROC
  49. Replaces the address of the window procedure associated with the class.
  50. dwNewLong
  51. Specifies the replacement value.
  52. Return Values
  53. If the function succeeds, the return value is the previous value of the specified 32-bit integer.
  54. If the function fails, the return value is zero. To get extended error information, call GetLastError.
  55. Remarks
  56. If you use the SetClassLong function and the GCL_WNDPROC index to
  57. replace the window procedure, the window procedure must conform to
  58. the guidelines specified in the description of the WindowProc callback function.
  59. Calling SetClassLong with the GCL_WNDPROC index creates a subclass
  60. of the window class that affects all windows subsequently created with
  61. the class. An application should not subclass a window created by another process.
  62. Reserve extra class memory by specifying a nonzero value in the
  63. cbClsExtra member of the WNDCLASS structure used with the
  64. RegisterClass function.
  65. Use the SetClassLong function with care. For example, it is possible to
  66. change the background color for a class by using SetClassLong, but this
  67. change does not immediately repaint all windows belonging to the class.
  1. [COLOR=Blue]CreateSolidBrush   [/COLOR]
  2. The CreateSolidBrush function creates a logical brush that has the specified solid color.
  3. HBRUSH CreateSolidBrush( COLORREF crColor
  4. // brush color value
  5. );
  6.
  7. Parameters
  8. crColor
  9. Specifies the color of the brush.
  10. Return Values
  11. If the function succeeds, the return value identifies a logical brush.
  12. If the function fails, the return value is NULL.
  13. Remarks
  14. A solid brush is a bitmap that Windows uses to paint the interiors of filled shapes.
  15. After an application creates a brush by calling CreateSolidBrush, it can
  16. select that brush into any device context by calling the SelectObject function.
复制代码
GMT+8, 2026-11-6 00:16 , Processed in 0.407825 second(s), 34 queries , Gzip On.
