查看: 818|回复: 2
[求助] [求助]:炸开多重嵌套块的循环结构?
发表于 2004-6-15 15:45:47 | 显示全部楼层 |阅读模式
用lisp语句怎样写?
块内的块也得炸开.
发表于 2004-6-17 01:04:36 | 显示全部楼层
(vl-cmdf "xplode" (ssget "X" '((0 . "BLOCK"))))
发表于 2004-6-17 20:56:21 | 显示全部楼层
轉貼代碼.  樓主你可以參考這個
(defun c:xex ()
  (princ "\n炸開嵌套塊.--------------by 無痕.2004.4")
  (setvar "qaflags" 1)
  (setq ss (ssget '((0 . "INSERT"))))
  (while (setq ss (ssget "P" '((0 . "INSERT"))))
    (command ".explode" ss "")
  )(princ)
To 樓上的大俠, 你的炸開塊代碼有點美中不足改一下
(vl-cmdf "explode" (ssget "X" '((0 . "INSERT"))))
GMT+8, 2026-11-4 22:54 , Processed in 0.463250 second(s), 36 queries , Gzip On.
