查看: 900|回复: 3
[编程申请]:一次性修改同一图层的多义线线宽
发表于 2004-6-16 08:33:18 | 显示全部楼层 |阅读模式
一次性修改同一图层的多义线线宽.,保留多义线的特性!
 楼主| 发表于 2004-6-16 08:41:36 | 显示全部楼层
采用炸开命令的结果,很多义线变成了线段。我希望能够保持多义线的特性,只改变线宽。
发表于 2004-6-16 10:09:07 | 显示全部楼层
请参考:
(defun c:test ()
  (vl-load-com)
  (setq pl (car (entsel "\npick pline on the layer: ")))
  (initget 5)
  (setq w (getreal "\ninput the width of pline: "))
  (setq lay (cdr (assoc 8 (entget pl))))
  (setq ss (ssget "x" (list (cons 8 lay)(cons 0 "lwpolyline"))))
  (setq n 0)
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (vla-put-constantwidth obj w)
    (setq n (1+ n))
 楼主| 发表于 2004-6-18 07:51:11 | 显示全部楼层
谢谢lsjjm  黄金长老
GMT+8, 2026-11-6 19:13 , Processed in 0.432601 second(s), 38 queries , Gzip On.
