查看: 1024|回复: 6
[求助] [求助]:*.FAS是如何生成的?
已领礼包: 10个
发表于 2004-6-16 15:59:36 | 显示全部楼层 |阅读模式
如题,请各位大侠指教。谢谢!!!
发表于 2004-6-16 19:55:47 | 显示全部楼层
lisp编译后生成的文件!
发表于 2004-6-17 09:31:59 | 显示全部楼层
cad200x以上版本vlisp提供的一个编译功能而生成的文件
发表于 2004-6-17 10:48:54 | 显示全部楼层
Re: [求助]:*.FAS是如何生成的?
最初由 HJZ 发布
[B]如题,请各位大侠指教。谢谢!!! [/B]
  1.   [FONT=courier new]
  2. Compiles AutoLISP source code into a FAS file
  3. (vlisp-compile 'mode filename [out-filename])
  4. Note  The Visual LISP IDE must be open in order for vlisp-compile to work.
  5. Arguments
  6. mode
  7. The compiler mode, which can be one of the following symbols:
  8. st  Standard build mode
  9. lsm  Optimize and link indirectly
  10. lsa  Optimize and link directly
  11. filename
  12. A string identifying the AutoLISP source file. If the source file is in the AutoCAD Support File Search Path, you can omit the path when specifying the file name. If you omit the file extension, .lsp is assumed.
  13. out-filename
  14. A string identifying the compiled output file. If you do not specify an output file, vlisp-compile names the output with the same name as the input file, but replaces the extension with .fas.
  15. Note that if you specify an output file name but do not specify a path name for either the input or the output file, vlisp-compile places the output file in the AutoCAD install directory.
  16. Return Values
  17. T, if compilation is successful; otherwise nil.
  18. Examples
  19. Assuming that yinyang.lsp resides in a directory that is in the AutoCAD Support File Search Path, the following command compiles this program:
  20. _$ (vlisp-compile 'st "yinyang.lsp")
  21. T
  22. The output file is named yinyang.fas and resides in the same directory as the source file.
  23. The following command compiles yinyang.lsp and names the output file GoodKarma.fas:
  24. (vlisp-compile 'st "yinyang.lsp" "GoodKarma.fas")
  25. Note that the output file from the previous command resides in the AutoCAD install directory, not the directory where yinyang.lsp resides. The following command compiles yinyang.lsp and directs the output file to the c:\my documents directory:
  26. (vlisp-compile 'st "yinyang.lsp" "c:/my documents/GoodKarma")
  27. This last example identifies the full path of the file to be compiled:
  28. (vlisp-compile `st "c:/program files/AutoCAD 2004/Sample/yinyang.lsp")
  29. The output file from this command is named yinyang.fas and resides in the same directory as the input file.
  30.   [/FONT]
复制代码
发表于 2004-6-17 17:19:50 | 显示全部楼层
使用命令在——visual lisp 控制台
(VLISP-COMPILE 'st "xxx.LSP")
xxx.LSP是lisp文件名
会出现
(COMPILE-FILES st (D:/Acadwlq/OK/TOT3.LSP))
[分析文件 "D:/Acadwlq/OK/TOT3.LSP"]
[COMPILING D:/Acadwlq/OK/TOT3.LSP]
;;C:TOTNUM
;;C:L2P
;;C:TOTLINE
;;C:TOTAREA
[FASDUMPING 对象格式 -> "D:/Acadwlq/OK/TOT3.fas"]
; 编译完成。
忘了告诉各位:不带路径的文件名必须是在cad配置的搜索路径中,否则就要写全路径。
发表于 2004-6-17 20:07:51 | 显示全部楼层
已领礼包: 10个
 楼主| 发表于 2004-6-17 22:36:57 | 显示全部楼层
谢谢,各位大侠,明白了!!!
GMT+8, 2026-11-4 23:40 , Processed in 0.488724 second(s), 44 queries , Gzip On.
