查看: 1651|回复: 9
[求助]:小妹头回做水池!!求助高手指点指点
发表于 2004-6-19 22:06:18 | 显示全部楼层 |阅读模式
那位朋友帮我验算一下,这样算法对不对,我在这里先谢了.
矩 形 水 池 计 算
设 计 资 料:
建在山坡上,露天开口循环水池,无地下水位,粘性土回填,摩擦角30,埋深4m, 池内水位Hw=4m,水池长度H=30m, 水池宽度B=24m, 池壁高度h0=4m, 底板外伸C1=500(mm),底板厚度h1=300(mm) ,池壁厚h4=300(mm),垫层厚度h3= 100 (mm) ,地基承载力设计值R=120(KPa)
________________________________________________________________________________________
一.地基承载力验算
( 1 )底板面积AR1 = (H + 2 * h4 + 2 * C1) * (B + 2 * h4 + 2 * C1)
= ( 30 + 2 * .25 + 2 * .3 ) * ( 24 + 2 * .25 + 2 * .3 )
=780.6(m^2)
( 2 )顶板面积AR2 = (H + 2 * h4) * (B + 2 * h4)
= ( 30 + 2 * .25 ) * ( 24 + 2 * .25 )
=747.2(m^2)
( 3 )池顶荷载Pg = P1 + ht * 18
= 0 + 0 * 18
=0 (KN/m^2)
( 4 )池壁重量CB = 25 * (H + 2 * h4 + * 2 * H0 * h4
= 25 * ( 30 + 2 * .25 + 24 )* 2 * 4 * .25
=2725 (KN)
( 5 )底板重量DB1 = 25 * AR1 * h1
= 25 * 780.6 * .25
=4878.(KN)
( 6 )顶板重量DB2 = 25 * AR2 * h2
= 25 *747.2 * 0
=0 (KN)
( 7 )水池全重G = CB + DB1 + DB2 + Fk1
=2725 +4878.+0 +0
=7603 (KN)
( 8 )单位面积水重Pwg = (H * B * Hw * 10) / AR1
= ( 30 * 24 * 4 * 10) / 780.6
=36.89(KN/m^2)
( 9 )单位面积垫层重Pd = 23 * h3
= 23 * .1
=2.94(KN/m^2)
( 10 )地基反力R0 = Pg + G / AR1 + Pwg + Pd
=0 + 7603 / 780.6 + 36.89 + 2.94
= 50 (KN/m^2)
R0 = 50 (KN/m^2) < R = 90(KN /m^2) 地基承载力满足要求!
二.水池整体抗浮验算
地下水位在底板以下,不需验算
三.水池局部抗浮验算
地下水位在底板以下,不需验算
四.荷 载 计 算
(1)池内水压Pw= rw * H0 = 10 * 4 = 40 (KN/m^2)
(2)池外土压Pt:
池壁顶端Pt2 = [Pg + rt * (ht + h2)] * [Tan(45-φ/2) ^ 2]
= [0 + 18 * ( 0 + 0 )] * [Tan(45-30/2) ^ 2]
= 0 (KN/m^2)
池壁底端Pt1 = [Pg + rt * (ht + h2 + H0)] * [Tan(45-φ/2) ^ 2]
= [0 + 18 * ( 0 + 0 + 4 )] * [Tan(45-30/2) ^ 2]
= 23.99(KN/m^2)
池底荷载qD = Pg + (Fk1 + C / AR2
= 0 +(0 +2725 ) / 747.2
= 3.490(KN/m^2)
五.内 力 计 算
(H边)池壁内力计算
H / H0 =30000 /4000=7.5
由于 H / H0 > 3
故按竖向单向板(挡土墙)计算池壁内力
1.池外(土、水)压力作用下池壁内力
Pt0 = Pt1 - Pt2=23.99 -0 = 23.99 (KN/m^2)
底 端 弯 矩Mn2 = -(Pt1 + 2 * Pt2) * (H0 ^ 2) / 6
= -(23.99 + 2 * 0 ) * ( 4 ^ 2) / 6
= -63.(KN-m)
角隅最大弯矩Mj1 = -0.426 * Pt1 * H0 ^ 2
= -0.426 *23.99 * 4 ^ 2
= 0 (KN-m)
2.池内水压力作用下池壁内力
底 端 弯 矩Mw2 = -(Pw * H0 ^ 2) / 6
= -( 40 * 4 ^ 2) / 6
= -42.(KN-m)
角隅最大弯矩Mj2 = -0.104 * Pw * H0 ^ 2
= -0.104 * 40 * 4 ^ 2
= -66.(KN-m)
由于B边池壁高度与H边相同,故计算从略,内力计算结果参见H边池壁计算。
竖板按土压力作用悬臂板计算:
α=M/fcm.b.h2=63000000/16.5.1000.265.265=0.054
γ=0.5(1+√1-2α)=0.5(1+√1-2x0.054)=0.972
As=M/fy.γ.h=63000000/310x0.972x265=788
竖板混凝土C30配10@100,分布筋8@150,
底板按构造混凝土C30配双层双向10@200
不知这样算行不行??高手请给小妹一点见意吧。也可介绍一些差不多的水池成功经验给我小妹听听啊,小妹在此期盼各位大侠的回音
如果在池内竖板底部加扶壁(斜撑):上宽500 ,下宽1000,高2000,宽250,间距6000,又怎么计算?望高手指点。
另外我想问一些问题,在线的话加我QQ112539869,等急....
*-*5*-*a *-*c *-*5
 楼主| 发表于 2004-6-20 09:04:21 | 显示全部楼层
高手帮下小妹啊,发表一些看法啊
发表于 2004-6-28 16:07:21 | 显示全部楼层
裂缝不算了?
发表于 2004-7-21 12:52:07 | 显示全部楼层
我提出一些看法:
1. 底板外挑500,但是底板却只有300。墙壁厚300,底板厚度是可以大于或等于300的,而外挑这部分由于有土的自重在上面,有个弯矩平衡的问题,而且,扩散角也会破坏到底板。建议外挑尺寸与底板厚度相同或小点。
2 . 配筋小了。根据现在的新规范,水工构筑物的构造钢筋都是有最小配筋率要求的。壁厚300的构造钢筋,都是405mm2,要配到12@200了。
计算过程还没详细看,呵呵。
以上只是本人的一些拙见,不妥之处请指出。
发表于 2004-7-22 16:42:38 | 显示全部楼层 |阅读模式
我也提一点看法,不知对不对:
墙壁厚300有点大,250就可以了;外挑的板当悬臂构件考虑,根部加厚就可以了。
发表于 2004-7-25 07:25:31 | 显示全部楼层
如果水池上方做停车位的话,池壁做300还厚吗?请高手指点!
发表于 2004-7-30 23:20:08 | 显示全部楼层
具体的计算我没有仔细看,但我注意到你没有进行池壁间及池壁与池底间的弯矩分配传递。
发表于 2004-8-13 08:55:26 | 显示全部楼层
水池抗裂怎么算
发表于 2004-8-16 14:22:49 | 显示全部楼层 |阅读模式
我是菜鸟 以后希望各位多多指教呀 有好的经验可以给我分享
发表于 2004-8-17 17:49:17 | 显示全部楼层
1.除构造底板外,建议底板厚度不要小于池壁,最好是大于池壁厚度100mm以上。好处是,池壁可看作固结于底板,将池壁做悬臂板考虑;而同时池壁对于底板只是铰结,底板弯矩不再反传到池壁上。这样水池力的传递路线会明确的多。
2.对于单向板池壁,根部竖向弯矩和水平向角隅弯矩是需要主要控制的数值,也是计算配筋的重点。而对于大多数水池结构,强度计算都不是重点,重点是裂缝控制。一般裂缝计算通过,强度大都是没问题的。以你的这个水池为例,4米水头,单向板,根部竖向弯矩为106.7knm(你的计算公式对的,但结果算错了),按给水构筑物0.25mm的裂缝控制计算,受弯构件,计算根部竖向配筋得16◎100(裂缝0.240mm)。所以你的配筋是不够的。对于角隅处,则需要按偏心受拉计算水平钢筋控制裂缝。
3.你没有计算底板内力配筋。
GMT+8, 2026-11-23 17:14 , Processed in 0.311883 second(s), 28 queries , Gzip On, File On.
