查看: 855|回复: 0
[编程申请]:如何可编一可连续画线的程序(很急)谢谢!!!
发表于 2004-7-1 19:43:27 | 显示全部楼层 |阅读模式
1。求助:输入八个定点坐标自动联成一立方体
2。疑惑:为什么下面调用画圆程序后,只能画出一个画圆,在调用则显示不出圆实体
程序如下:
void rdscir()
//画圆命令
AcDbObjectId CirId=AcDbObjectId::kNull;
AcGeVector3d normal(0.0,0.0,1.0);
AcGePoint3d center;
ads_real radius;
ads_point pt1;
//初始化输入状态
acedInitGet(RSG_NONULL+RSG_DASH,NULL);
acedGetPoint(NULL,"请输入圆心坐标",pt1);
acedInitGet(RSG_NONULL+RSG_NONEG+RSG_NOZERO,NULL);
acedGetDist(pt1,"入圆的半径",&radius);
center=asPnt3d(pt1);
AcDbCircle *pCirc=new AcDbCircle(center,normal,radius);
//出错处理
if(pCirc==NULL)
return;
postToDb(pCirc,CirId);//将实体写入数据库
void postToDb(AcDbEntity *pEnt,AcDbObjectId &entId)
        AcDbBlockTable *pBlockTable;
//打开块表纪录
Acad::ErrorStatus es=acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForRead);
//如果打开失败,删除圆
if(es!=Acad::eOk)
{delete pEnt;
return;//返回
AcDbBlockTableRecord *pBlockTableRecord;
//打开块表纪录
es=pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
if(es!=Acad::eOk)
{  Acad::ErrorStatus es2=pBlockTable->close();
   if(es2!=Acad::eOk)
{//弹出严重错误对话框
     //acrx_abort("\nApp X failed to close Block Table.Error:%d",acadErrorStatusText(es2));
delete pEnt;
return;
//关闭块表
es=pBlockTable->close();
if(es!=Acad::eOk)
{    //acrx_abort("\nApp X failed to close Block" "Table.Error:%d", acadErrorStatusText(es));
//将实体写入块表纪录并返回ID号
es=pBlockTableRecord->appendAcDbEntity(entId,pEnt);
if(es!=Acad::eOk)
{  Acad::ErrorStatus es2=pBlockTableRecord->close();
  if(es2!=Acad::eOk)
    {//acrx_abort("\nApp X failed to close "
          //  "Model Space Block Record.Error:%s",
          //  acadErrorStatusText(es2));
  delete pEnt;
  return;
//关闭块表纪录
if(es!=Acad::eOk)
    {acrx_abort("\nApp X failed to  "
           "Model Space Block Record.Error:%d")
          //  acadErrorStatusText(es));
//关闭实体纪录
es=pEnt->close();
if (es!=Acad::eOk)
        acrx_abort("\nApp X faild to"
                "close entity.Error:%d")
return;
GMT+8, 2026-11-5 22:03 , Processed in 0.489209 second(s), 32 queries , Gzip On.
