查看: 1123|回复: 2
[ARX程序]:回:篮木头 ViewAllBlock
发表于 2004-7-4 22:53:48 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. CImageList * Utils::ViewAllBlock(const char* pFileName)
  3. {
  4.         CBitmap *pBitmap = NULL;
  5.         CImageList *pImageList = new CImageList();
  6.         pImageList->Create(32,32,FALSE,0,1);
  7.         CString sFile = WinUtils::CreatTempFile(_T(""));
  8.         Acad::ErrorStatus es;
  9.         AcDbBlockTable *pTable = NULL;
  10.         AcDbBlockTableRecord *pRec = NULL;
  11.         AcDbBlockTableRecord::PreviewIcon PreviewIcon;
  12.         AcDbDatabase *pDb = NULL;
  13.         bool bHas = false;
  14.         AcDbBlockTableIterator* pIT = NULL;
  15.         int i = 0;
  16.         BITMAPFILEHEADER bfHeader;
  17.         BITMAPINFOHEADER biHeader;
  18.         DWORD dwTmp;
  19.         HANDLE hf;         // file handle
  20.
  21.         biHeader.biSize = 40;
  22.         biHeader.biWidth = 32;
  23.         biHeader.biHeight = 32;
  24.         biHeader.biPlanes = 1;
  25.         biHeader.biBitCount = 8;
  26.         biHeader.biCompression = 0;
  27.         biHeader.biSizeImage = 1024;
  28.         biHeader.biXPelsPerMeter = 0;
  29.         biHeader.biYPelsPerMeter = 0;
  30.         biHeader.biClrUsed = 0;
  31.         biHeader.biClrImportant = 0;
  32.
  33.         //
  34.         int clrTableSize;
  35.         if (biHeader.biBitCount < 9)
  36.         {
  37.                 clrTableSize = 4 * ldexp(1, biHeader.biBitCount);
  38.         }
  39.         else
  40.         {
  41.                 clrTableSize = 0;
  42.         }
  43.
  44.         //        ' Fill the BITMAPFILEHEADER structure
  45.         bfHeader.bfType = 0x4d42;  // 0x42 = "B" 0x4d = "M"  // ' Image type
  46.         bfHeader.bfSize = (DWORD) (sizeof(BITMAPFILEHEADER) + biHeader.biSize + clrTableSize + biHeader.biSizeImage); //' Length of file (in bytes)
  47.         bfHeader.bfOffBits = (DWORD) (sizeof(BITMAPFILEHEADER) + biHeader.biSize + clrTableSize);
  48.     bfHeader.bfReserved1 = 0;
  49.     bfHeader.bfReserved2 = 0;
  50.
  51.         if (pFileName == _T(""))
  52.         {
  53.                 pDb = acdbCurDwg();
  54.                 pDb->getBlockTable(pTable,AcDb::kForRead);
  55.
  56.                 if (Acad::eOk != pTable->newIterator( pIT ))
  57.                 {
  58.                         pTable->close();
  59.                         return NULL;
  60.                 }
  61.                 for (pIT->start(); !pIT->done(); pIT->step())
  62.                 {
  63.                         if (pIT->getRecord(pRec,AcDb::kForRead) != Acad::eOk)
  64.                         {
  65.                                 pTable->close();return NULL;
  66.                         }
  67.                         bHas = pRec->hasPreviewIcon();
  68.                         if (bHas)
  69.                         {
  70.                                 pRec->getPreviewIcon(PreviewIcon);
  71.                                 // Create the .BMP file.
  72.                                 hf = CreateFile(sFile, GENERIC_READ | GENERIC_WRITE, (DWORD) 0, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, (HANDLE) NULL);
  73.
  74.                                 // Copy the BITMAPFILEHEADER into the .BMP file.
  75.                                 if (!WriteFile(hf, (LPVOID) &bfHeader, sizeof(BITMAPFILEHEADER),(LPDWORD) &dwTmp,  NULL))
  76.                                 {
  77.                                         CloseHandle(hf); pRec->close();pTable->close();
  78.                                         return NULL;
  79.                                 }
  80.
  81.                                 int nLength = PreviewIcon.length();
  82.                                 for (i = 0; i< nLength;i++)
  83.                                 {
  84.                                         BYTE BTemp = PreviewIcon.at(i);
  85.                                         if (!WriteFile(hf, (LPVOID)&BTemp, 1,(LPDWORD) &dwTmp,  NULL))
  86.                                         {
  87.                                                 CloseHandle(hf);pRec->close();pTable->close();
  88.                                                 return NULL;
  89.                                         }
  90.                                 }
  91.
  92.                                 // Close the .BMP file.
  93.                                 if (!CloseHandle(hf)) {pRec->close();pTable->close();return NULL;}
  94.                                 pBitmap = new CBitmap();
  95.                                 HBITMAP hBitmap;
  96.                                 hBitmap = (HBITMAP)LoadImage(NULL, sFile, IMAGE_BITMAP, 0, 0,LR_LOADFROMFILE | LR_CREATEDIBSECTION | LR_DEFAULTSIZE);
  97.                                 if (!hBitmap)
  98.                                 {
  99.                                         pRec->close();pTable->close();
  100.                                         return NULL;
  101.                                 }
  102.                                 CBitmap Bitmap;
  103.                                 pBitmap = Bitmap.FromHandle(hBitmap);
  104.
  105.                                 int ii = pImageList->Add(pBitmap,RGB(0,0,0));
  106.                         }
  107.                         pRec->close();
  108.                 }
  109.                 pTable->close();
  110.         }
  111. else{
  112. .....
  113. }
  114.         delete pIT;
  115.         return pImageList;
  116.
  117. }
  118.   [/FONT]
复制代码
这个程序被我丢弃了很长时间了,差点找不着了,呵呵.
因为是以前写的,有很多漏洞,请大家指出
刚发现:如果不成功,要delete pImageList;
发表于 2004-7-5 13:59:20 | 显示全部楼层
谢谢你了,帮了我大忙了。希望大家多交流交流
发表于 2008-7-11 16:07:23 | 显示全部楼层
怎么还有。。。?
不过还是学习了:)
GMT+8, 2026-11-4 05:05 , Processed in 0.430780 second(s), 35 queries , Gzip On.
