查看: 539|回复: 0
[讨论]:等效侧移刚度计算问题
发表于 2004-7-14 13:15:59 | 显示全部楼层 |阅读模式
请教高手,等效侧移刚度的计算问题,转换层上下部分数据如下
           各层刚心、偏心率、相邻层侧移刚度比等计算信息
  Floor No     : 层号
  Tower No     : 塔号
  Xstif,Ystif : 刚心的 X,Y 坐标值
  Alf          : 层刚性主轴的方向
  Xmass,Ymass : 质心的 X,Y 坐标值
  Gmass        : 总质量
  Eex,Eey     : X,Y 方向的偏心率
  Ratx,Raty   : X,Y 方向本层塔侧移刚度与下一层相应塔侧移刚度的比值
  Ratx1,Raty1 : X,Y 方向本层塔侧移刚度与上一层相应塔侧移刚度70%的比值
                 或上三层平均侧移刚度80%的比值中之较小者
  RJX,RJY,RJZ: 结构总体坐标系中塔的侧移刚度和扭转刚度
  Floor No.   1     Tower No.   1
  Xstif=    14.8259(m)     Ystif=     8.6063(m)     Alf  =    -0.1750(Degree)
  Xmass=    15.2853(m)     Ymass=     7.1956(m)     Gmass=   983.0352(t)
  Eex  =     0.0328        Eey  =     0.1408
  Ratx =     1.0000        Raty =     1.0000
  Ratx1=     4.7872        Raty1=     2.8975  薄弱层地震剪力放大系数= 1.00
  RJX  = 7.3056E+09(kN/m)  RJY  = 1.1563E+09(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   2     Tower No.   1
  Xstif=    14.8262(m)     Ystif=     8.6062(m)     Alf  =    -0.1825(Degree)
  Xmass=    15.2856(m)     Ymass=     7.1956(m)     Gmass=   983.0573(t)
  Eex  =     0.0328        Eey  =     0.1409
  Ratx =     0.2984        Raty =     0.4930
  Ratx1=   369.8669        Raty1=    57.9137  薄弱层地震剪力放大系数= 1.00
  RJX  = 2.1801E+09(kN/m)  RJY  = 5.7010E+08(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   3     Tower No.   1
  Xstif=    15.3355(m)     Ystif=     8.3934(m)     Alf  =    -0.1770(Degree)
  Xmass=    14.0077(m)     Ymass=     7.2474(m)     Gmass=   658.8130(t)
  Eex  =     0.0957        Eey  =     0.1165
  Ratx =     0.0039        Raty =     0.0247
  Ratx1=     2.1235        Raty1=     2.0532  薄弱层地震剪力放大系数= 1.00
  RJX  = 8.4204E+06(kN/m)  RJY  = 1.4063E+07(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   4     Tower No.   1
  Xstif=    15.2486(m)     Ystif=     8.3434(m)     Alf  =     0.1681(Degree)
  Xmass=    17.0703(m)     Ymass=     7.4223(m)     Gmass=   942.6028(t)
  Eex  =     0.1310        Eey  =     0.0947
  Ratx =     0.6727        Raty =     0.6958
  Ratx1=     2.0315        Raty1=     1.9023  薄弱层地震剪力放大系数= 1.00
  RJX  = 5.6648E+06(kN/m)  RJY  = 9.7848E+06(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   5     Tower No.   1
  Xstif=    15.5566(m)     Ystif=     8.6587(m)     Alf  =     0.1621(Degree)
  Xmass=    14.8659(m)     Ymass=     7.2075(m)     Gmass=   704.5337(t)
  Eex  =     0.0421        Eey  =     0.1398
  Ratx =     0.7032        Raty =     0.7510
  Ratx1=     1.6486        Raty1=     1.7961  薄弱层地震剪力放大系数= 1.00
  RJX  = 3.9836E+06(kN/m)  RJY  = 7.3483E+06(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   6     Tower No.   1
  Xstif=    15.7563(m)     Ystif=     8.6209(m)     Alf  =     0.1593(Degree)
  Eex  =     0.0540        Eey  =     0.1355
  Ratx =     0.8420        Raty =     0.7954
  Ratx1=     1.5244        Raty1=     1.6597  薄弱层地震剪力放大系数= 1.00
  RJX  = 3.3541E+06(kN/m)  RJY  = 5.8448E+06(kN/m)  RJZ  = 0.0000E+00(kN/m)
高位转换时转换层上部与下部结构的等效侧向刚度比
               转换层所在层号=     3
转换层下部结构起止层号及高度=     1     3      8.90
转换层上部结构起止层号及高度=     4     6      8.70
X方向下部刚度= 0.8378E+07   X方向上部刚度= 0.1378E+07   X方向刚度比= 0.1608[/COLOR]
Y方向下部刚度= 0.1356E+08   Y方向上部刚度= 0.2443E+07   Y方向刚度比= 0.1761[/COLOR]
不知各位在建模时是否包括地下室?如果包括地下室,转换层下部的刚度肯定大于其上部的刚度,那《高规》附录E.0.1,E.0.2,岂不是很容易满足?
GMT+8, 2026-11-3 02:13 , Processed in 0.432630 second(s), 30 queries , Gzip On.
