查看: 1446|回复: 3
[VBA函数]:如何在AUTOCAD的VBA中把块炸开?
发表于 2002-12-6 16:39:32 | 显示全部楼层 |阅读模式
如题
因为需要转换到其它格式。
多谢大侠指教
谢谢
发表于 2002-12-6 17:04:33 | 显示全部楼层
有explode方法的。
已领礼包: 181个
发表于 2002-12-6 17:45:26 | 显示全部楼层
附上例子。
  1.   [FONT=courier new]
  2. Sub Ch10_ExplodingABlock()
  3.     ' 定义块
  4.     Dim blockObj As AcadBlock
  5.     Dim insertionPnt(0 To 2) As Double
  6.     insertionPnt(0) = 0
  7.     insertionPnt(1) = 0
  8.     insertionPnt(2) = 0
  9.     Set blockObj = ThisDrawing.Blocks.Add _
  10.                      (insertionPnt, "CircleBlock")
  11.
  12.     ' 添加圆到块中
  13.     Dim circleObj As AcadCircle
  14.     Dim center(0 To 2) As Double
  15.     Dim radius As Double
  16.     center(0) = 0
  17.     center(1) = 0
  18.     center(2) = 0
  19.     radius = 1
  20.     Set circleObj = blockObj.AddCircle(center, radius)
  21.
  22.     ' 插入块
  23.     Dim blockRefObj As AcadBlockReference
  24.     insertionPnt(0) = 2
  25.     insertionPnt(1) = 2
  26.     insertionPnt(2) = 0
  27.     Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock _
  28.                (insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
  29.     MsgBox "The circle belongs to " & blockRefObj.ObjectName
  30.
  31.     ' 炸开块引用
  32.     Dim explodedObjects As Variant
  33.     explodedObjects = blockRefObj.Explode
  34.
  35.     ' 枚举炸开的实体对象
  36.     Dim I As Integer
  37.     For I = 0 To UBound(explodedObjects)
  38.         explodedObjects(I).Color = acRed
  39.         explodedObjects(I).Update
  40.         MsgBox "Exploded Object " & I & ": " _
  41.                             & explodedObjects(I).ObjectName
  42.         explodedObjects(I).Color = acByLayer
  43.         explodedObjects(I).Update
  44.     Next
  45. End Sub
  46.   [/FONT]
 楼主| 发表于 2002-12-8 21:05:00 | 显示全部楼层
多谢。
已经解决。
GMT+8, 2026-11-2 17:15 , Processed in 0.423869 second(s), 38 queries , Gzip On.
