查看: 2593|回复: 3
[求助] [求助]:请问谁有自动生成填充文件(pat文件)的程序啊?
发表于 2002-12-8 12:08:41 | 显示全部楼层 |阅读模式
发表于 2002-12-8 12:41:49 | 显示全部楼层
试试看,以前在R14下试过没问题。
另,这段代码好像参考了陈老师书中的类似代码,特别说明一下。
  1. (defun c:patm (/ str_pat str_desc ss1 f_id index obj ent1 typ
  2.                     pt_start pt_end ang1 dis1 shift_x shift_y
  3.                     dis_space w1$ q0 lst_hatch np_x np_y
  4.                     x_wk y_wk grid_num)
  5.   (setq grid_num 100)
  6. (setq str_pat "" str_desc "")
  7.   (while (not (and (/= "" (setq str_pat (getstring "\nPattern name (file name): "))
  8.                        (< 9 (strlen str_pat))
  9.   ))));while
  10.   (while (= "" (setq str_desc (getstring "\nDescription: " t))))
  11.   (princ "\nSelect unit pattern entities...")
  12.   (while (not (setq ss1 (ssget))))
  13.
  14.   (princ "\n  PATMaker analysing entities....")
  15.   (setq f_id (open (strcat str_pat ".pat") "w"))
  16.   (princ (strcat "*" str_pat) f_id)
  17.   (write-line (strcat "," str_desc) f_id)
  18.   (setq index 0
  19.         ss1_len (sslength ss1))
  20.   (while (< index ss1_len)
  21.     (setq obj (ssname ss1 index)
  22.           ent1 (entget obj)
  23.           typ (dxf 0 ent1)
  24.           index (1+ index))
  25.     (setq do_id 0)
  26.     (cond
  27.       ((= typ "POINT") (setq w1$ (strcat "0," (rtos (car (dxf 10 ent1)) 2 6) ","
  28.                                          (rtos (cadr (dxf 10 ent1)) 2 6)
  29.                                        ",0,1,0,-1"
  30.                                  ))
  31.        (prompt (strcat "\n" w1$))
  32.        (write-line w1$ f_id)
  33.       )
  34.       ((= typ "LINE")
  35.        (setq pt_start (dxf 10 ent1)
  36.              pt_end (dxf 11 ent1)
  37.              ang1 (angle pt_start pt_end)
  38.              ang2 (angle pt_end pt_start)
  39.              dis1 (distance pt_start pt_end)
  40.        );setq
  41.
  42.        ;----------------------------------
  43.        (cond
  44.          ( (or (QAEC_EQ (car pt_start)(car pt_end))
  45.                (QAEC_EQ (cadr pt_start)(cadr pt_end)))
  46.            (setq shift_x 0.0
  47.                  shift_y 1.0
  48.                  dis_space (- dis1 1))
  49.          ); V line
  50.          ( T
  51.            (if (> (car pt_start)(car pt_end))
  52.              (setq p_wk pt_end
  53.                    pt_end pt_start
  54.                    pt_start p_wk)
  55.            );if
  56.            (setq ang1 (angle pt_start pt_end)
  57.            );setq
  58.            ; ------------ find space -------------------
  59.            (setq np_x (- (car pt_end)(car pt_start))
  60.                  np_y (- (cadr pt_end)(cadr pt_start)))
  61.            (if (>= np_x 0)
  62.              (setq np_x (fix (+ (* np_x grid_num) 0.5)))
  63.              (setq np_x (fix (- (* np_x grid_num) 0.5)))
  64.            );if
  65.            (if (>= np_y 0)
  66.              (setq np_y (fix (+ (* np_y grid_num) 0.5)))
  67.              (setq np_y (fix (- (* np_y grid_num) 0.5)))
  68.            );if
  69.            (setq lst2 (get_simple np_x np_y))
  70.
  71.            (setq np_x (car lst2) np_y (cadr lst2))
  72.            (setq np_x (+ np_x (car pt_start))
  73.                  np_y (+ np_y (cadr pt_start)))
  74.            (setq dis_w (distance pt_start (list np_x np_y)))
  75.            (setq dis_space (- dis1 dis_w))
  76.
  77.            ;---------------- Find shift distance -------------------
  78.            ; when angle equal to 45 or 315
  79.            (if (or (equal ang1 (* 0.25 pi) 0.01)
  80.                    (equal ang1 (* 1.75 pi) 0.01))
  81.              (if (> (cadr pt_start)(cadr pt_end))
  82.                (setq shift_x (cos (+ pi ang1))
  83.                      shift_y (sin (+ pi ang1)))
  84.                (setq shift_x (cos (- pi ang1))
  85.                      shift_y (sin (- pi ang1)))
  86.              );if
  87.              (progn ; other angles
  88.                (setq x (car lst2) y (cadr lst2) y1 (abs y) y_wk dis_w)
  89.                (setq n 1 ptt_x (car pt_start) ptt_y (cadr pt_start))
  90.                (repeat x
  91.                  (if (> y 0)
  92.                    (setq m 1)
  93.                    (setq m -1)
  94.                  );if
  95.                  (repeat y1
  96.                    (setq pt_wk (list (+ n ptt_x)(+ m ptt_y))
  97.                          ang3 (angle pt_start pt_wk)
  98.                          dis3 (distance pt_start pt_wk)
  99.                          y_wk1 (* dis3 (sin (- ang3 ang1)))
  100.                    );steq
  101.                    (if (< (abs y_wk1) (abs y_wk))
  102.                      (if (not (and (= n x)(= m y)))
  103.                        (setq y_wk y_wk1
  104.                              pt_keep pt_wk
  105.                              x_wk (* dis3 (cos (- ang3 ang1)))
  106.                        );setq
  107.                      );if
  108.                    );if
  109.                    (if (> y 0)
  110.                      (setq m (1+ m))
  111.                      (setq m (1- m))
  112.                    );if
  113.                  );repeat
  114.                  (setq n (1+ n))
  115.                );repeat
  116.                (setq shift_x x_wk shift_y y_wk)
  117.              );progn - all other angles
  118.            );if
  119.          ); Other lines
  120.        );cond
  121.        ;-------------------------------------
  122.        (setq w1$ (strcat (angtos ang1 0 3) ","
  123.                          (rtos (car pt_start) 2 6) ","
  124.                          (rtos (cadr pt_start) 2 6) ","
  125.                          (rtos shift_x 2 6) ","
  126.                          (rtos shift_y 2 6) ","
  127.                          (rtos dis1 2 6) ","
  128.                          (rtos dis_space 2 6)
  129.                  ))
  130.        ;(princ (strcat "\n" w1$))
  131.        (write-line w1$ f_id)
  132.       ) ;type line end
  133.       (T
  134.         (princ (strcat typ " skipped,"))
  135.       )
  136.     )
  137.   )
  138.   (write-char 26 f_id)
  139.   (close f_id)
  140.
  141.   (princ " finished!")
  142.   (alert (strcat "OK!\n\n  File <" str_pat ".pat> created in current directory. "))
  143.   (princ)
  144. )
  145. (princ)
  146. (defun dxf (num lst)
  147.   (cdr (assoc num lst))
  148. )
  149. ; 求最简分数
  150. (defun get_simple (num1 num2 / py px n_w swich_id m out_lst)
  151.    (setq px (abs num1) py (abs num2))
  152.    (if (< py px)
  153.      (setq n_w px px py py n_w swich_id T)
  154.      (setq swich_id nil)
  155.    );if
  156.
  157.    (setq m 2)
  158.    (while (<= m px)
  159.     (if (and (eq (rem py m) 0)(eq (rem px m) 0))
  160.       (progn
  161.         (setq py (/ py m)
  162.               px (/ px m)
  163.               m 2)
  164.       );progn
  165.       (setq m (1+ m))
  166.     );if
  167.   );while
  168.   (if swich_id
  169.     (setq n_w px px py py n_w swich_id nil)
  170.   );if
  171.   (if (< num1 0)(setq px (- 0 px)))
  172.   (if (< num2 0)(setq py (- 0 py)))
  173.
  174.   (list px py)
  175. );end
  176. (princ "\n**PATMaker v1.0 loaded! Type 'PATM' to start.")
  177. (princ)
 楼主| 发表于 2002-12-8 12:57:34 | 显示全部楼层
在acad2002下说QAEC_EQ这个函数找不到
发表于 2002-12-8 19:20:08 | 显示全部楼层
Sorry,忘记了:
  1. (defun QAEC_EQ (a b)
  2.   (if (equal a b 1e-005) T nil)
  3. );end
GMT+8, 2026-11-3 06:15 , Processed in 0.507565 second(s), 38 queries , Gzip On.
