查看: 1142|回复: 4
[LISP程序]:搞到一个定义填充图案的程序
发表于 2004-7-22 10:13:23 | 显示全部楼层 |阅读模式
发过来给大家共享。
不过是被加密的,希望大虾把它解密了。
发表于 2004-7-22 20:09:11 | 显示全部楼层
谁能把变量改得好认一点儿?
改了一晚上,还是有不少内容猜不出来!猜出来的也不一定恰当!
好象里面缺两个自定义函数!应该是这两句里的:
;;;         (NOT (PatFile@ PatFile))
;;;         (Q$@ PatFile (STRCAT PatName ".pat"))
PatFile@、Q$@ !
主程序基本差不多了!
  1. (DEFUN Qj (Q@ / QQ Ql Q& Q1)
  2.   (SETQ Ql 1
  3.         Q& ""
  4.         QQ (IF (GETENV "COMSPEC")
  5.              "\"
  6.              "/"
  7.            ) ;_ end of IF
  8.   ) ;_ end of SETQ
  9.   (WHILE (/= "" (SETQ Q1 (SUBSTR Q@ Ql 1)))
  10.     (SETQ Q& (STRCAT Q&
  11.                      (IF (MEMBER Q1 (quote ("\" "/")))
  12.                        QQ
  13.                        Q1
  14.                      ) ;_ end of IF
  15.              ) ;_ end of STRCAT
  16.           Ql (1+ Ql)
  17.     ) ;_ end of SETQ
  18.   ) ;_ end of WHILE
  19.   (IF (AND (/= Q& "") (/= (SUBSTR Q& (STRLEN Q&) 1) QQ))
  20.     (SETQ Q& (STRCAT Q& QQ))
  21.   ) ;_ end of IF
  22.   Q&
  23. ) ;_ end of DEFUN
  24. (DEFUN GetPatFile (PatFile / Q$ PatFileOpen Q@ Q1 Q|)
  25.   (SETQ Ql -1
  26.         Q% (STRLEN PatFile)
  27.         Q$ ""
  28.   ) ;_ end of SETQ
  29.   (WHILE (AND (/= Q% (1+ Ql)) (NOT Q@))
  30.     (IF (MEMBER (SETQ Q1 (SUBSTR PatFile (- Q% (SETQ Ql (1+ Ql))) 1))
  31.                 (quote ("/" "\"))
  32.         ) ;_ end of MEMBER
  33.       (SETQ Q@ (SUBSTR PatFile 1 (- Q% Ql)))
  34.       (SETQ Q$ (STRCAT Q1 Q$))
  35.     ) ;_ end of IF
  36.   ) ;_ end of WHILE
  37.   (IF Q@
  38.     NIL
  39.     (SETQ Q@ "")
  40.   ) ;_ end of IF
  41.   (WHILE (AND (/= "Q" Q@)
  42.               (NOT (SETQ PatFile (FINDFILE (STRCAT (Qj Q@) Q$))))
  43.          ) ;_ end of AND
  44.     (SETQ Q| (STRCAT "\n\nFile "
  45.                      Q$
  46.                      " not found in "
  47.                      (IF (= "" Q@)
  48.                        "current directory,"
  49.                        Q@
  50.                      ) ;_ end of IF
  51.                      "\nEnter path to search, or Q to quit: "
  52.              ) ;_ end of STRCAT
  53.           Q@ (STRCASE (GETSTRING Q|))
  54.     ) ;_ end of SETQ
  55.   ) ;_ end of WHILE
  56.   (IF (= "Q" Q@)
  57.     (PROGN (PROMPT "File not found. ") NIL)
  58.     (SUBSTR (Qj PatFile) 1 (STRLEN PatFile))
  59.   ) ;_ end of IF
  60. ) ;_ end of DEFUN
  61. (DEFUN GetObjectType (GroupCode         Q@j)
  62.   (CDR (ASSOC GroupCode         Q@j))
  63. ) ;_ end of DEFUN
  64. (PROMPT
  65.   "Type AUTOPAT to create a hatch pattern from a 1 unit by 1 unit sample pattern"
  66. ) ;_ end of PROMPT
  67. (DEFUN C:AUTOPAT (/ PatName PatDes SelectionOfPatEnt PatFileOpen Counter NameOfEnt DataOfEnt ObjectType StartPoint  EndPoint  AngleOfLine LengthOfLine CosineValue
  68.                   SineValue SpacingOfLine SpacingOfPat PatFile)
  69.   (SETQ PatName ""
  70.         PatDes ""
  71.   ) ;_ end of SETQ
  72.   (WHILE (NOT (AND (/= ""
  73.                        (SETQ PatName (GETSTRING "\nName of pattern: "))
  74.                        (< 9 (STRLEN PatName))
  75.                    ) ;_ end of /=
  76.               ) ;_ end of AND
  77.          ) ;_ end of NOT
  78.   ) ;_ end of WHILE
  79.   (WHILE (= "" (SETQ PatDes (GETSTRING "\nDescription: " T))))
  80.   (PROMPT "\nSelect unit pattern entities...")
  81.   (WHILE (NOT (SETQ SelectionOfPatEnt (SSGET))))
  82.   (SETQ PatFileOpen (OPEN (STRCAT PatName ".pat") "w"))
  83.   (TEXTSCR)
  84.   (PRINC (STRCAT "*" PatName) PatFileOpen)
  85.   (WRITE-LINE (STRCAT "," PatDes) PatFileOpen)
  86.   (SETQ Counter 0
  87.         LengthOfSelection (SSLENGTH SelectionOfPatEnt)
  88.   ) ;_ end of SETQ
  89.   (WHILE (< Counter LengthOfSelection)
  90.     (SETQ NameOfEnt (SSNAME SelectionOfPatEnt Counter)
  91.           DataOfEnt (ENTGET NameOfEnt)
  92.           ObjectType (GetObjectType 0 DataOfEnt)
  93.           Counter (1+ Counter)
  94.     ) ;_ end of SETQ
  95.     (SETQ Q1@ 0)
  96.     (COND
  97.       ((= ObjectType "POINT")
  98.        (SETQ SpacingOfPat (STRCAT "0,"
  99.                          (RTOS (CAR (GetObjectType 10 DataOfEnt)) 2 6)
  100.                          ","
  101.                          (RTOS (CADR (GetObjectType 10 DataOfEnt)) 2 6)
  102.                          ",0,1,0,-1"
  103.                  ) ;_ end of STRCAT
  104.        ) ;_ end of SETQ
  105.        (PROMPT (STRCAT "\n" SpacingOfPat))
  106.        (WRITE-LINE SpacingOfPat PatFileOpen)
  107.       )
  108.       ((= ObjectType "LINE")
  109.        (SETQ StartPoint  (GetObjectType 10 DataOfEnt)
  110.              EndPoint  (GetObjectType 11 DataOfEnt)
  111.              AngleOfLine (ANGLE StartPoint  EndPoint )
  112.              NegativeAngleOfLine (ANGLE EndPoint  StartPoint )
  113.              LengthOfLine (DISTANCE StartPoint  EndPoint )
  114.        ) ;_ end of SETQ
  115.        (IF
  116.          (= "1.00"
  117.             (RTOS
  118.               (+ (SETQ CosineValue (ABS (COS AngleOfLine)))
  119.                  (SETQ SineValue (ABS (SIN AngleOfLine))))
  120.               2
  121.               2
  122.             ) ;_ end of RTOS
  123.          ) ;_ end of =
  124.           (SETQ CosineValue 0.0
  125.                 SineValue 1.0
  126.                 SpacingOfLine (- LengthOfLine SineValue)
  127.                 Q1@ 1
  128.           ) ;_ end of SETQ
  129.        ) ;_ end of IF
  130.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 172.875)
  131.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 172.875)
  132.            ) ;_ end of OR
  133.          (PROGN (SETQ SineValue -0.1240)
  134.                 (SETQ CosineValue 7.07)
  135.                 (SETQ SpacingOfLine (- LengthOfLine 8.0623))
  136.                 (SETQ Q1@ 1)
  137.          ) ;_ end of PROGN
  138.        ) ;_ end of IF
  139.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 165.964)
  140.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 165.964)
  141.            ) ;_ end of OR
  142.          (PROGN (SETQ SineValue 0.2425)
  143.                 (SETQ CosineValue 0.9701)
  144.                 (SETQ SpacingOfLine (- LengthOfLine 4.1231))
  145.                 (SETQ Q1@ 1)
  146.          ) ;_ end of PROGN
  147.        ) ;_ end of IF
  148.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 153.435)
  149.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 153.435)
  150.            ) ;_ end of OR
  151.          (PROGN (SETQ SineValue 0.4472)
  152.                 (SETQ CosineValue 0.8944)
  153.                 (SETQ SpacingOfLine (- LengthOfLine 2.2361))
  154.                 (SETQ Q1@ 1)
  155.          ) ;_ end of PROGN
  156.        ) ;_ end of IF
  157.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 143.130)
  158.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 143.130)
  159.            ) ;_ end of OR
  160.          (PROGN (SETQ SineValue 0.2)
  161.                 (SETQ CosineValue 3.6)
  162.                 (SETQ SpacingOfLine (- LengthOfLine 5))
  163.                 (SETQ Q1@ 1)
  164.          ) ;_ end of PROGN
  165.        ) ;_ end of IF
  166.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 135)
  167.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 135)
  168.            ) ;_ end of OR
  169.          (PROGN (SETQ SineValue 0.7071)
  170.                 (SETQ CosineValue 0.7071)
  171.                 (SETQ SpacingOfLine (- LengthOfLine 1.4142))
  172.                 (SETQ Q1@ 1)
  173.          ) ;_ end of PROGN
  174.        ) ;_ end of IF
  175.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 116.565)
  176.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 116.565)
  177.            ) ;_ end of OR
  178.          (PROGN (SETQ SineValue 0.4472)
  179.                 (SETQ CosineValue 1.3416)
  180.                 (SETQ SpacingOfLine (- LengthOfLine 2.2361))
  181.                 (SETQ Q1@ 1)
  182.          ) ;_ end of PROGN
  183.        ) ;_ end of IF
  184.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 123.690)
  185.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 123.690)
  186.            ) ;_ end of OR
  187.          (PROGN (SETQ SineValue 0.2774)
  188.                 (SETQ CosineValue 1.3868)
  189.                 (SETQ SpacingOfLine (- LengthOfLine 3.6056))
  190.                 (SETQ Q1@ 1)
  191.          ) ;_ end of PROGN
  192.        ) ;_ end of IF
  193.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 104.036)
  194.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 104.036)
  195.            ) ;_ end of OR
  196.          (PROGN (SETQ SineValue 0.2425)
  197.                 (SETQ CosineValue 3.153)
  198.                 (SETQ SpacingOfLine (- LengthOfLine 4.1231))
  199.                 (SETQ Q1@ 1)
  200.          ) ;_ end of PROGN
  201.        ) ;_ end of IF
  202.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 97.125)
  203.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 97.125)
  204.            ) ;_ end of OR
  205.          (PROGN (SETQ SineValue 0.1240)
  206.                 (SETQ CosineValue 7.07)
  207.                 (SETQ SpacingOfLine (- LengthOfLine 8.0623))
  208.                 (SETQ Q1@ 1)
  209.          ) ;_ end of PROGN
  210.        ) ;_ end of IF
  211.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 82.875)
  212.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 82.875)
  213.            ) ;_ end of OR
  214.          (PROGN (SETQ SineValue 0.1240)
  215.                 (SETQ CosineValue 0.9923)
  216.                 (SETQ SpacingOfLine (- LengthOfLine 8.0623))
  217.                 (SETQ Q1@ 1)
  218.          ) ;_ end of PROGN
  219.        ) ;_ end of IF
  220.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 75.964)
  221.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 75.964)
  222.            ) ;_ end of OR
  223.          (PROGN (SETQ SineValue 0.2425)
  224.                 (SETQ CosineValue 0.9701)
  225.                 (SETQ SpacingOfLine (- LengthOfLine 4.1231))
  226.                 (SETQ Q1@ 1)
  227.          ) ;_ end of PROGN
  228.        ) ;_ end of IF
  229.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 63.435)
  230.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 63.435)
  231.            ) ;_ end of OR
  232.          (PROGN (SETQ SineValue 0.4472)
  233.                 (SETQ CosineValue 0.8944)
  234.                 (SETQ SpacingOfLine (- LengthOfLine 2.2361))
  235.                 (SETQ Q1@ 1)
  236.          ) ;_ end of PROGN
  237.        ) ;_ end of IF
  238.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 4)) 56.3099)
  239.                (= (READ (ANGTOS NegativeAngleOfLine 0 4)) 56.3099)
  240.            ) ;_ end of OR
  241.          (PROGN (SETQ SineValue 0.2774)
  242.                 (SETQ CosineValue 2.2188)
  243.                 (SETQ SpacingOfLine (- LengthOfLine 3.6056))
  244.                 (SETQ Q1@ 1)
  245.          ) ;_ end of PROGN
  246.        ) ;_ end of IF
  247.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 45)
  248.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 45)
  249.            ) ;_ end of OR
  250.          (PROGN (SETQ SineValue 0.7071)
  251.                 (SETQ CosineValue 0.7071)
  252.                 (SETQ SpacingOfLine (- LengthOfLine 1.4142))
  253.                 (SETQ Q1@ 1)
  254.          ) ;_ end of PROGN
  255.        ) ;_ end of IF
  256.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 4)) 36.8699)
  257.                (= (READ (ANGTOS NegativeAngleOfLine 0 4)) 36.8699)
  258.            ) ;_ end of OR
  259.          (PROGN (SETQ SineValue 0.2)
  260.                 (SETQ CosineValue 1.4)
  261.                 (SETQ SpacingOfLine (- LengthOfLine 5.0))
  262.                 (SETQ Q1@ 1)
  263.          ) ;_ end of PROGN
  264.        ) ;_ end of IF
  265.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 26.565)
  266.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 26.565)
  267.            ) ;_ end of OR
  268.          (PROGN (SETQ SineValue 0.4472)
  269.                 (SETQ CosineValue 1.3416)
  270.                 (SETQ SpacingOfLine (- LengthOfLine 2.236))
  271.                 (SETQ Q1@ 1)
  272.          ) ;_ end of PROGN
  273.        ) ;_ end of IF
  274.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 14.036)
  275.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 14.036)
  276.            ) ;_ end of OR
  277.          (PROGN (SETQ SineValue 0.2425)
  278.                 (SETQ CosineValue 3.1530)
  279.                 (SETQ SpacingOfLine (- LengthOfLine 4.1231))
  280.                 (SETQ Q1@ 1)
  281.          ) ;_ end of PROGN
  282.        ) ;_ end of IF
  283.        (IF (OR (= (READ (ANGTOS AngleOfLine 0 3)) 7.125)
  284.                (= (READ (ANGTOS NegativeAngleOfLine 0 3)) 7.125)
  285.            ) ;_ end of OR
  286.          (PROGN (SETQ SineValue 0.1240)
  287.                 (SETQ CosineValue 7.0700)
  288.                 (SETQ SpacingOfLine (- LengthOfLine 8.0623))
  289.                 (SETQ Q1@ 1)
  290.          ) ;_ end of PROGN
  291.        ) ;_ end of IF
  292.        (IF (= Q1@ 1)
  293.          (PROGN (SETQ SpacingOfPat (STRCAT (ANGTOS AngleOfLine 0 3)
  294.                                   ","
  295.                                   (RTOS (CAR StartPoint ) 2 6)
  296.                                   ","
  297.                                   (RTOS (CADR StartPoint ) 2 6)
  298.                                   ","
  299.                                   (RTOS CosineValue 2 6)
  300.                                   ","
  301.                                   (RTOS SineValue 2 6)
  302.                                   ","
  303.                                   (RTOS LengthOfLine 2 6)
  304.                                   ","
  305.                                   (RTOS SpacingOfLine 2 6)
  306.                           ) ;_ end of STRCAT
  307.                 ) ;_ end of SETQ
  308.                 (PROMPT (STRCAT "\n" SpacingOfPat))
  309.                 (WRITE-LINE SpacingOfPat PatFileOpen)
  310.          ) ;_ end of PROGN
  311.          (PROGN (PROMPT (STRCAT "\nLine found at invalid angle "
  312.                                 (ANGTOS AngleOfLine 0 3)
  313.                                 " will not be included in hatch\n"
  314.                         ) ;_ end of STRCAT
  315.                 ) ;_ end of PROMPT
  316.          ) ;_ end of PROGN
  317.        ) ;_ end of IF
  318.       )
  319.       (T (PROMPT (STRCAT "\nInvalid entity" ObjectType " skipped.")))
  320.     ) ;_ end of COND
  321.   ) ;_ end of WHILE
  322.   (WRITE-CHAR 26 PatFileOpen)
  323.   (CLOSE PatFileOpen)
  324.   (SETQ PatFile (GetPatFile "ACAD.PAT"))
  325.   (INITGET "Yes No")
  326.   (IF
  327.     (AND (/= "" PatFile)
  328.          (/= "No"
  329.              (GETKWORD
  330.                (STRCAT
  331.                  "\n"
  332.                  PatName
  333.                  ".pat file may be appended to ACAD.PAT for general use."
  334.                  "\nDo you want to append to "
  335.                  PatFile
  336.                  " and delete "
  337.                  PatName
  338.                  ".pat? Yes/No/<Y>: "
  339.                 ) ;_ end of STRCAT
  340.              ) ;_ end of GETKWORD
  341.          ) ;_ end of /=
  342.          (NOT (PatFile@ PatFile))
  343.          (Q$@ PatFile (STRCAT PatName ".pat"))
  344.     ) ;_ end of AND
  345.      NIL
  346.      (PROMPT
  347.        (STRCAT "\n" PatName ".pat file left in current directory. ")
  348.      ) ;_ end of PROMPT
  349.   ) ;_ end of IF
  350.   (GRAPHSCR)
  351.   (PRINC)
  352. ) ;_ end of DEFUN
  353. (PRINC)
发表于 2004-7-28 22:31:01 | 显示全部楼层
不知为何,定义图案易出错
已领礼包: 488个
发表于 2004-7-29 00:07:03 | 显示全部楼层
网上找找,应该可以找到现成的.
发表于 2004-7-29 07:34:59 | 显示全部楼层
最初由 sztk2001 发布
[B]不知为何,定义图案易出错 [/B]
上面的程序好象只能定义点和线,并且线的角度是限定的几种,
这可能是出错的原因吧!
还有因为里面少了两个自定义函数,如果将pat定义追加到acad.pat的话会出错,如果不追加,而已单独pat文件存在,好象不会出问题!
我只定义过45度和90度直线组成的图案!
GMT+8, 2026-11-5 00:07 , Processed in 0.452289 second(s), 41 queries , Gzip On.
