查看: 607|回复: 1
[求助]:好心人帮忙解释一下程序
发表于 2004-7-31 11:28:31 | 显示全部楼层 |阅读模式
void lwpoly()
        AcDbDatabase *pCurDb;
        AcDbBlockTable *pBlkTable;
        AcDbBlockTableRecord *pBlkTableRecord;
        AcDbPolyline *pPolyEnt;
        AcDbObjectId polyId;
        AcGePoint2d pkPt;
        AcGePoint2dArray arPts;
        ads_point pick, lastpt;
        AcGeMatrix3d ucsMat;
        AcGeMatrix2d ucsMat2d;
        int retCode;
        int numPts;
        Adesk::Boolean keepPicking = Adesk::kTrue;
        Adesk::Boolean firstPick = Adesk::kTrue
        acdbUcsMatrix(ucsMat);
        ucsMat2d(0,0) = ucsMat(0,0);
        ucsMat2d(0,1) = ucsMat(0,1);
        ucsMat2d(0,2) = ucsMat(0,3);
        ucsMat2d(1,0) = ucsMat(1,0);
        ucsMat2d(1,1) = ucsMat(1,1);
        ucsMat2d(1,2) = ucsMat(1,3);
        while(keepPicking)
                if(firstPick)
                        retCode = acedGetPoint(NULL, "\nPick first point: ", pick);
                        firstPick = Adesk::kFalse;
                else
                        acdbPointSet(pick, lastpt);
                        retCode = acedGetPoint(pick, "\nPick another point - [ENTER] for no more: ", pick);
                        acedGrDraw(lastpt, pick, 1, 0);
                if(retCode != RTNORM)
                        keepPicking = Adesk::kFalse;
                        break;
                pkPt.x = pick[X];
                pkPt.y = pick[Y];
AcGePoint2dArray    arPts.append(pkPt);
        acedRedraw(NULL, 1);
        if(arPts.isEmpty())
                acutPrintf("\nEmpty array.");
                return;
                if(arPts.length() < 2)
                acutPrintf("\nArray only contains one point.");
                return;
        numPts = arPts.length();
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
        pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
        pBlkTable->close();
        pPolyEnt = new AcDbPolyline(numPts);
        for(int idx = 0; idx < numPts; idx++)
                pkPt = arPts.at(idx);
                pkPt.transformBy(ucsMat2d);
                pPolyEnt->addVertexAt(idx, pkPt);
        pBlkTableRecord->appendAcDbEntity(polyId, pPolyEnt);
        pBlkTableRecord->close();
        pPolyEnt->close();
主要是pPolyEnt = new AcDbPolyline(numPts)前的部分
AcArray类模板不好理解
最好能帮助帮助注释一下
谢谢
发表于 2004-8-5 14:30:04 | 显示全部楼层
C++的书讲有类模板
AcArray相当于一个基类,可以为很多数组类型服务,以相同的操作相同的接口实现相同的结果
GMT+8, 2026-11-5 23:23 , Processed in 0.553086 second(s), 33 queries , Gzip On.
