查看: 2427|回复: 16
[求助]:关于cao库中的createlink 方法
发表于 2002-12-16 10:55:31 | 显示全部楼层 |阅读模式
各位老大,cao库中的createLink方法中的关键值keys要怎样赋值呀?
比如说:dim keys as new cao.keyvalues
                dim keyval as new cao.keyvalue
                dim lint as cao.link
                 keys.clear
                 keyval.value = rsSpaces!SPACE_ID
                 keys.Add keyval
                set objlink=Linkt.createlink(objpoly,objectID, keys)
以上语句编译时老是通不过,错误在 keys.add keyval 这里。
还望各位老大多多指教
已领礼包: 181个
发表于 2002-12-16 13:04:45 | 显示全部楼层
还没对KeyValue对象赋值吧,先设置FieldName 、Value属性,设置完后,再调用Add 方法试试。
 楼主| 发表于 2002-12-16 13:18:13 | 显示全部楼层
Sub populateOfficeDatabase()
    ' Variables for AutoCAD objects
    Dim objPoly As AutoCAD.AcadLWPolyline
    Dim objText As AutoCAD.AcadText
    Dim polySel As AutoCAD.AcadSelectionSet
    ' Variables for ADO objects
    Dim rsSpaces As New ADODB.Recordset
    Dim rsUseTypes As New ADODB.Recordset
    Dim rsEmployee As New ADODB.Recordset
    Dim rsDepartment As New ADODB.Recordset
    ' Variables for DCO objects
    Dim LinkT As CAO.LinkTemplate
    Dim keys As New CAO.KeyValues
    Dim keyval As New CAO.KeyValue
    Dim objLink As CAO.link
    ' Other variables
    Dim wsPath As String
    Dim useType As String
    Dim DeptName(1 To 6) As String
    Dim i As Long
    ' Store the department names in an array
    DeptName(1) = "Civil Engineering"
    DeptName(2) = "Architecture"
    DeptName(3) = "Planning"
    DeptName(4) = "Landscape Architecture"
    DeptName(5) = "Surveying"
    DeptName(6) = "Admin"
    ' Verify that the SPACES link template exists
    On Error Resume Next
    Set LinkT = getLinkTemplate(SpacesLink)
    If Err <> 0 Then
        MsgBox "You must first create a Link Template named '" & _
            SpacesLink & "'" & _
            vbCrLf & "based on the SPACES_QUERY table (SPACE_ID field)", _
            vbOKOnly, "Office Example"
        Exit Sub
    End If
    On Error GoTo 0
    ' Verify that the user really wants to do this
    If MsgBox("This will clear the OFFICE database " & _
            "and delete all links. Do you want to continue?", _
            vbYesNo, "Office Example") = vbNo Then
        Exit Sub
    End If
    ' Delete all links associated with this link template
    ThisDrawing.Utility.Prompt "Deleting links..." & vbCrLf
    For Each objLink In getDbConnect().GetLinks(LinkT)
        objLink.Delete
    Next
    ' Open the database
    openConnection SpacesLink
    ' Delete all rows from all tables
    ' (in case we run this macro more than once)
    ThisDrawing.Utility.Prompt "Clearing the database..." & vbCrLf
    getAdoConnection().Execute "delete from employee"
    getAdoConnection().Execute "delete from spaces"
    getAdoConnection().Execute "delete from use_types"
    getAdoConnection().Execute "delete from department"
    ' Open the Recordset objects
    rsSpaces.Open "SPACES", getAdoConnection(), _
        adOpenDynamic, adLockOptimistic
    rsUseTypes.Open "USE_TYPES", getAdoConnection(), _
    rsEmployee.Open "EMPLOYEE", getAdoConnection(), _
    rsDepartment.Open "DEPARTMENT", getAdoConnection(), _
    ' Iterate through the space polygons and populate the database
    Set polySel = getSpacePolylineSelection()
    For Each objPoly In polySel
        ' Find a text object inside the polygon
        Set objText = getTextInsidePolygon(objPoly)
        If Not objText Is Nothing Then
            ' Determine what the use of the space is. If the polygon
            ' color is set, then it's an office and the text is the
            ' employee name or "Vacant". Otherwise use the text value
            ' found inside the polygon as the use type.
            useType = "Office"
            If objPoly.Color = acByLayer Then
                useType = objText.TextString
                If useType = "Vacant" Then
                    useType = "Office"
                End If
            End If
            ' Add the use type to the USE_TYPES table if it does not exist
            rsUseTypes.Find "TYPE_NAME='" & useType & _
                "'", , , adBookmarkFirst
            If rsUseTypes.EOF Then
                rsUseTypes.AddNew
                rsUseTypes!TYPE_NAME = useType
                rsUseTypes.Update
            End If
            ' Add a new row to the spaces table
            rsSpaces.AddNew
            rsSpaces!TYPE_ID = rsUseTypes!TYPE_ID
            rsSpaces.Update
            ' Set up the key value for the link
            keys.Clear
            keyval.Value = rsSpaces!SPACE_ID
            keys.Add keyval
            ' Create the link on the polygon
            Set objLink = LinkT.CreateLink(objPoly.ObjectID, keys)
            ' This is an occupied office...
            If objText.Color = acByLayer _
                And objPoly.Color <> acByLayer Then
                ' Add the department name to the DEPARTMENT
                ' table if necessary
                rsDepartment.Find "DEPT_NAME='" & _
                    DeptName(objPoly.Color) & "'", , , adBookmarkFirst
                If rsDepartment.EOF Then
                    rsDepartment.AddNew
                    rsDepartment!DEPT_NAME = DeptName(objPoly.Color)
                    rsDepartment.Update
                End If
                ' Split the first and last name by finding the position
                ' of the separating space
                i = InStr(1, objText.TextString, " ", vbTextCompare)
                ' Add a new row to the employee table and populate it
                rsEmployee.AddNew
                rsEmployee!FIRST_NAME = Left(objText.TextString, i - 1)
                rsEmployee!LAST_NAME = Mid(objText.TextString, i + 1)
                rsEmployee!DEPT_ID = rsDepartment!DEPT_ID
                rsEmployee!SPACE_ID = rsSpaces!SPACE_ID
                rsEmployee.Update
            End If
            ThisDrawing.Utility.Prompt objText.TextString
        End If
    Next
    ' Close the recorset objects
    rsSpaces.Close
    rsUseTypes.Close
    rsEmployee.Close
    rsDepartment.Close
    ' Release the polyline selection object
    Set polySel = Nothing
End Sub
编译时老在keys.add keyval 处出错
已领礼包: 181个
发表于 2002-12-16 13:26:58 | 显示全部楼层
这句的语法没错,你用下面的代码试试。
End Sub
  1.   [FONT=courier new]
  2. Sub Test()
  3.     Dim KVs As New CAO.KeyValues
  4.     Dim KV As New CAO.KeyValue
  5.     KVs.Clear
  6.     KV.FieldName = "C"
  7.     KV.Value = "A"
  8.     KVs.Add KV
  9.     MsgBox KVs(0).FieldName & ": " & KVs(0).Value
  10.   [/FONT]
 楼主| 发表于 2002-12-16 13:52:36 | 显示全部楼层
好象还是不行,编译时显示Argument not optional (Error 449)
光标还是出现在 keys.add keyval
老大,要不我把图和文件传给你看看
已领礼包: 181个
发表于 2002-12-16 13:54:41 | 显示全部楼层
你把图和程序上传上来吧,大家帮帮忙看看是什么问题。
 楼主| 发表于 2002-12-16 16:29:32 | 显示全部楼层
附件中有3个文件,分别为office.dvb, office.mdb, office.dwg
加载office.dvb后运行populatedatabase宏,然后就会出现
上述问题
已领礼包: 181个
发表于 2002-12-16 17:02:35 | 显示全部楼层
你一步步跟踪一下代码,好像返回的LinkTemplates的数量为0。
在编程中,最好少用On Error Resume Next,应该用On Error GoTo ErrTrap,ErrTrap为你处理错误的跳转标号,这里是你集中处理错误的地方,用Resume只能是一些无法集中处理或者能立刻结束错误的场合,因为它会把错误带到下一个语句和过程。
 楼主| 发表于 2002-12-17 09:06:02 | 显示全部楼层
efan兄,不好意思,那个联结模板是要自己建的。我忘了把它给联上了,
我现在连好了,再传上来。
我现在还是弄不懂那个add方法到底错在哪。呵呵,还望老大多多指导。
已领礼包: 181个
发表于 2002-12-17 11:45:54 | 显示全部楼层
缺少数据连接UDL文件。
 楼主| 发表于 2002-12-17 12:58:07 | 显示全部楼层
恩?office.mdb我在上个压缩包里面就发过了呀,
已领礼包: 181个
发表于 2002-12-17 13:05:51 | 显示全部楼层
最初由 catchy_sky 发布
[B]恩?office.mdb我在上个压缩包里面就发过了呀, [/B]
不是mdb文件,是udl文件,在CAD目录下,你查找一下。
 楼主| 发表于 2002-12-17 14:11:21 | 显示全部楼层
udl文件就是用mdb文件建立的,
在dbcconnect中用office.mdb新建数据源,就会生成
udl文件。
已领礼包: 181个
发表于 2002-12-17 14:26:49 | 显示全部楼层
那个语句没有错误,你跟踪一下是不是数据库的问题,可能它的权限设置成只写的。
下面是我创建的数据链接文件,你用它试一下,在我机上运行时一切正常。
 楼主| 发表于 2002-12-17 15:34:20 | 显示全部楼层
efan兄,你这个udl是用mdb建的吧,我用这个udl提示我找不到数据源,
因为你是在你的机器上建的udl,可能是mdb在不同的目录下吧。
如果你也是用那个mdb建的话,那就没有问题了,我在自己机器上建也
一样,至于你说的属性问题,我看了一下我的设置,没有问题!
还有我想问一下,你说在你的机器上一切运行正常,是不是所有的polyline都
建立了连接呢?还有office下的数据表有没有自动填充好呢?
我弄这个玩意都快一个月了,人都昏了,如果问了些benben的问题,请多见谅!
GMT+8, 2026-11-2 23:53 , Processed in 0.798436 second(s), 61 queries , Gzip On.
