查看: 678|回复: 4
[求助]:3D Autodesk_VIZ_2005的安装问题
发表于 2004-8-7 05:58:02 | 显示全部楼层 |阅读模式
我新买了D版viz2005安装不了,请高手帮我看看下面步骤如何操作。
1) Install, choose Network and Use any serial you want
2) install Autodesk Network License Manager located in nlm dir.
3) copy Licpath.lic into \Autodesk Network License Manager\License\
4) Start ..\Autodesk Network License Manager\lmtools.exe
5) into "Service/License File" select - Configuration using Services
   into "Config Services" - set Service Name "Viz 2005"
                          - set Path to the lmgrd.exe file
         "..\Autodesk Network License Manager\lmgrd.exe"
                           - set Path to the license file
         "..\Autodesk Network License Manager\License\License.txt"
                           - set Path to the debug log file
         "..\Autodesk Network License Manager\License\debug.txt
      - select "Start Server at Power Up" and "Use Services"
      - Save service
    into "Start/Stop/Reread" select "Viz 2005" and restart the server
6) You can close lmtools.exe now
7) enjoy another fine PARADOX-release!
发表于 2004-8-7 09:02:17 | 显示全部楼层
有3d6就可以了!viz2005是他的简化!
发表于 2004-8-8 16:27:44 | 显示全部楼层
最初由 xtltxk 发布
[B]有3d6就可以了!viz2005是他的简化! [/B]
VIZ3.0说是MAX3.0的简化还可以,到了VIZ2005可就不能这样简单的评价了。VIZ是AUTODESK专门为建筑人员推出的一款3D建模、RENDER、动画的集成软件,里面有众多的专门为建筑而设置的插件、模型、贴图等等,有着MAX不可替代的一些功能。
发表于 2004-8-11 00:46:39 | 显示全部楼层
是呀!捕捉锁定物体就是MAX里面没有的功能了!
发表于 2004-8-13 15:15:43 | 显示全部楼层
做建筑动画与MAX6有什么不同!
GMT+8, 2026-11-4 08:32 , Processed in 0.488473 second(s), 40 queries , Gzip On.
