查看: 656|回复: 1
[求助]:求MDT 2005 注册机
发表于 2004-8-8 13:10:16 | 显示全部楼层 |阅读模式
求MDT 2005 注册机
发表于 2004-8-9 12:45:27 | 显示全部楼层
终于找到了MDT2005注册法啦,现与大家分享
1. 复制文件夹 Autodesk Network License Manager 到硬盘;
2. 安装Autodesk.AutoCAD.Mechanical.v2005chs程序, (如果询问安装系列号采用 400-00000000 );
3. 复制文件夹 Autodesk Network License Manager 下的.dll 和 acad.exe 到安装目录;
4. 运行破解目录下acad tool.exe文件产生licpath.lic;
5. 将licpath.lic文件复制到 X:...\license\licpath.lic into ..\Autodesk
   Network License Manager\License\ folder;
6. 运行 lmtools.exe (Autodesk Network License Manager);
7. 在 "configuration using services" 标签栏生效;
8. 转换到“config services”标签栏
   在service name: "any name"
   path to the lmgrd.exe file: X:...\Autodesk Network License Manager\lmgrd.exe
   path to the license file: X:...\Autodesk Network License      Manager\License\Licpath.lic
   path to debug log file: X:...\Autodesk Network License Manager\License\
   enable use services
   enable start server at power up
   save service
   start/stop/repeat            "start server"
9. 编辑更改注册表regedit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R16.1\ACAD-305:804\AdLM]
"Type"=dword:00000019
(原值为0000002a)
10. 运行Autodesk.AutoCAD.Mechanical.v2005chs程序;
    出现对话框,提示选择是采用注册码激活还是选择许可文件,
    选择后者,并指向 X:...\Autodesk Network License
11. ok,enjoy it.
GMT+8, 2026-11-3 04:05 , Processed in 0.584961 second(s), 34 queries , Gzip On.
