查看: 954|回复: 6
[求助] [求助]:请问如何求得封闭spline的最小封闭区域,以及与最小封闭区域的四个切点呢?
发表于 2004-8-12 14:52:25 | 显示全部楼层 |阅读模式
请问如何求得封闭spline的最小矩形区域,以及与最小矩形区域的四个切点呢?
发表于 2004-8-12 15:03:14 | 显示全部楼层
Get the bounding box of the closed spline, then rotate the spline for a small degree, get it bounding box again and compare its area with the first one. Continue this process until it has rotated 360 degrees (180?).
 楼主| 发表于 2004-8-12 15:18:00 | 显示全部楼层
请问怎样才能"Get the bounding box of the closed spline"呢?在vl里用什么函数?
发表于 2004-8-12 15:24:06 | 显示全部楼层
(vla-getboundingbox splineobj 'LL 'UR)
 楼主| 发表于 2004-8-12 15:33:35 | 显示全部楼层
aidraft,thank you vary much.
发表于 2004-8-13 03:57:31 | 显示全部楼层
Re: [求助]:请问如何求得封闭spline的最小封闭区域,以及与最小封闭区域的四个切点呢?
最初由 leemanzhuo 发布
[B]请问如何求得封闭spline的最小矩形区域,以及与最小矩形区域的四个切点呢? [/B]
"最小矩形区域" 取决你如何定义. vla-getboundingbox函数只在
SPLINE所在区域的最长方向平行坐标轴时才返回正确的值.
发表于 2004-8-13 10:22:13 | 显示全部楼层
To some splines probably you need to do something before applying the GetBoundingBox method. For instance, offset a small distance to its right and then offset it back, or there are some functions available in this forum which can turn splines into polylines.
GMT+8, 2026-11-5 03:50 , Processed in 0.523910 second(s), 44 queries , Gzip On.
