查看: 952|回复: 3
[ARX函数]:请教各位大侠,如何将在块中的多义线的坐标读出来。
发表于 2004-8-13 10:14:38 | 显示全部楼层 |阅读模式
发表于 2004-8-13 13:51:03 | 显示全部楼层
跟读取模型空间的方法一样,只不过获取块表记录时要指定你自己的块名称,而不是ACDB_MODEL_SPACE了!
发表于 2004-8-13 14:54:39 | 显示全部楼层
[PHP]
AcDbBlockTableRecord *pBlockTableRecord;
AcDbBlockTableRecordIterator* pBlockIterator;
AcDbEntity *pEnt;
pBlockTableRecord->newIterator(pBlockIterator);
for(pBlockIterator->start();!pBlockIterator->done();pBlockIterator->step())
  pBlockIterator->getEntity(pEnt, AcDb::kForRead);
  ///................读出你的数据..............
  pEnt->close();
pBlockTableRecord->close();
[/PHP]
发表于 2004-8-13 15:33:50 | 显示全部楼层
这个可以的!
void ycreatedb()
AcDbDatabase *pDb = new AcDbDatabase();
    AcDbBlockTable *pBtbl;
    pDb->getSymbolTable(pBtbl, AcDb::kForWrite);
    AcDbBlockTableRecord *pBtblRcd;
    pBtbl->getAt(ACDB_MODEL_SPACE, pBtblRcd,AcDb::kForWrite);
    pBtbl->close();
                 AcGePoint3d pt,pt1,pt2,point3,point4,pointcenter;
                 AcGePoint3dArray ptArray;
                 double Par=20,height=30.0,radius=15;
                 double slopy , cosy , siny;
                 double eps=0.0001;
                 AcGeVector3d normal(0.0,0.0,1.0);
                 if(acedGetPoint(NULL,"\n请输入起点:",asDblArray(pt1))!=RTNORM)
                         return;
                 pt=pt1;
                 ptArray.append(pt);
                 for(;;)
                         if(acedGetPoint(asDblArray(pt1),"\n请输入下一点:",asDblArray(pt2))!=RTNORM)
                         break;
                         pt=pt2;
                         ptArray.append(pt);
          acutPrintf("\np1的坐标:%f,%f,%f",pt1.x,pt1.y,pt1.z);
          acutPrintf("\np1的坐标:%f,%f,%f",pt2.x,pt2.y,pt2.z);
                  pointcenter.x=(pt2.x+pt1.x)/2.00;
                  pointcenter.y=(pt2.y+pt1.y)/2.00;
                  pointcenter.z=0.00;
                  slopy = atan2( ( pt1.y-pointcenter.y   ),( pt1.x - pointcenter.x  ) );
                  cosy = cos( slopy );
                  siny = sin( slopy );
                  Acad::ErrorStatus es;
                  AcGePoint2d arrowpoint,arrowpoint1;
                  arrowpoint.x=pointcenter.x;
                  arrowpoint.y=pointcenter.y;
                  arrowpoint1.x=arrowpoint.x-20.0*cosy;
                  arrowpoint1.y=arrowpoint.y-20.0*siny;
                        point3.x=pt1.x-radius*cosy;
                        point3.y=pt1.y-radius*siny;
                        point3.z=pt1.z;
                        point4.x=pt2.x+radius*cosy;
                        point4.y=pt2.y+radius*siny;
                        point4.z=pt2.z;
                                AcDbLine *Line= new AcDbLine(point3,point4);//画线
                                Line->setColorIndex(7);
                                acedGrDraw(asDblArray(pt1),asDblArray(pt2),-1,0); //在屏幕上画出连接Ptl,Pt2的向量用来显示画线过程
                                pBtblRcd->appendAcDbEntity(Line);
                Line->close();
                                AcDbPolyline * arrPLine = new AcDbPolyline(2);
                                es= arrPLine->addVertexAt(0,arrowpoint1,0.0,0,10);
                                es= arrPLine->addVertexAt(1,arrowpoint);
                                pBtblRcd->appendAcDbEntity(arrPLine);
                arrPLine->close();
                        AcDbCircle *Circle = new AcDbCircle(pt1,normal,radius);
            pBtblRcd->appendAcDbEntity(Circle);
                        Circle->close();
                         pt1=pt2;
                 AcDbCircle * cire = new AcDbCircle(pt2,normal,radius);
         pBtblRcd->appendAcDbEntity(cire);
         cire->close();
         pBtblRcd->close();
    pDb->saveAs("vengraph.dwg");
    delete pDb;
        acutPrintf("\n完成读取数据库,退出程序!");
// This is command 'READDB'
void yreaddb()
    AcDbDatabase *pDb = new AcDbDatabase(Adesk::kFalse);
    // 向AcDbDatabase 构造函数传递kFlase参数,
        if(pDb->readDwgFile("vengraph.dwg")!=Acad::eOk)
           acutPrintf("\n 不能打开指定文件,退出程序!");
           return;
    // 打开模型空间记录.
    AcDbBlockTable *pBlkTbl;
    pDb->getSymbolTable(pBlkTbl, AcDb::kForRead);
    AcDbBlockTableRecord *pBlkTblRcd;
    pBlkTbl->getAt(ACDB_MODEL_SPACE, pBlkTblRcd,AcDb::kForRead);
    pBlkTbl->close();
    AcDbBlockTableRecordIterator *pBlkTblRcdItr;
    pBlkTblRcd->newIterator(pBlkTblRcdItr);
    AcDbEntity *pEnt;
    for (pBlkTblRcdItr->start(); !pBlkTblRcdItr->done();pBlkTblRcdItr->step())
        pBlkTblRcdItr->getEntity(pEnt,
            AcDb::kForRead);
        acutPrintf("类名: %s\n",(pEnt->isA())->name());
        pEnt->close();
    pBlkTblRcd->close();
    delete pBlkTblRcdItr;
    delete pDb;
// This is command 'LTDB'
void yltdb()
        CString xdbh,strSql;
        int index3=0;
        int p1;
        double radius=15.0,spoly,siny,cosy;
    double eps=0.001;
        AcGePoint3d arrowpoint,textpoint1;
        AcDbObjectId transId;
    AcDbDatabase* pDb;
    char *fname;
    struct resbuf *rb;
    // 获得用户需要的图形文件
    rb = acutNewRb(RTSTR);
    int stat = acedGetFileD("Pick a drawing", NULL, "dwg", 0, rb);
    if ((stat != RTNORM) || (rb == NULL))
                acutPrintf("\n用户没有指定文件名,退出程序!");
        return;
    fname = (char*)acad_malloc(strlen(rb->resval.rstring) + 1);
    strcpy(fname, rb->resval.rstring);
    acutRelRb(rb);
    // 打开指定文件.
    if (pDb->readDwgFile(fname) != Acad::eOk)
        acutPrintf("\n文件已被其他用户打开,退出程序!");
        return;
    AcDbBlockTable *pBlockTable;
    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pOtherMsBtr;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pOtherMsBtr, AcDb::kForRead);
    pBlockTable->close();
    // 创建一个迭代器.
    AcDbBlockTableRecordIterator *pIter;
    pOtherMsBtr->newIterator(pIter);
        AcGePoint3d pt1,pt2;
    // 创建一个对象ID队列,用于存储操作的ID对象.
    AcDbObjectIdArray objIdArray;
    //遍历块表记录找出所有直线
    for (pIter->start(); !pIter->done(); pIter->step())
                AcGePoint3d vertex;
        AcDbEntity *pEntity;
        pIter->getEntity(pEntity, AcDb::kForRead);
        if (pEntity->isKindOf(AcDbLine::desc()))
                        index3++;
                        p1=index3+1;
                        AcDbLine *Line = (AcDbLine*&)pEntity;
                        pt1=Line->startPoint();
                        pt2=Line->endPoint();
                 acutPrintf("\n直线的起点是:%d,%f,%f,%f",index3,pt1.x,pt1.y,pt1.z);
            acutPrintf("\n直线的终点是:%d,%f,%f,%f",p1,pt2.x,pt2.y,pt2.z);
                         spoly=atan2((pt1.y-pt2.y),(pt1.x-pt2.x));
                         siny=sin(spoly);
                         cosy=cos(spoly);
                      arrowpoint.x=(pt1.x+pt2.x)/2.0;
                 arrowpoint.y=(pt1.y+pt2.y)/2.0;
                          textpoint1.x=arrowpoint.x;
                          textpoint1.y=arrowpoint.y+radius;
                          textpoint1.z=pt1.z;
              xdbh.Format("%d",index3);
              AcDbObjectId text1Id;
                      AcDbText *jdbhText1 = new AcDbText(textpoint1,xdbh,text1Id,10,0);
              postToDatabase(jdbhText1,text1Id);
                          AcDbObjectId text2Id;
              AcDbText *jdbhText2 = new AcDbText(pt1,xdbh,text2Id,10,0);
              postToDatabase(jdbhText2,text2Id);
            objIdArray.append(pEntity->objectId());
                if(pEntity->isKindOf(AcDbCircle::desc()))
        pEntity->close();
    delete pIter;
    pOtherMsBtr->close();
    if (objIdArray.isEmpty())
        acad_free(fname);
        acutPrintf("\n指定的图形文件中没有直线对象,退出程序!");
        return;
    AcDbBlockTable *pThisBlockTable;
    acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pThisBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pThisMsBtr;
    pThisBlockTable->getAt(ACDB_MODEL_SPACE, pThisMsBtr, AcDb::kForWrite);
    pThisBlockTable->close();
    AcDbObjectId id = pThisMsBtr->objectId();
    pThisMsBtr->close();
    // 创建长事务管理器实例,并调出外部数据库的实体。
    AcDbIdMapping errorMap;
    acapLongTransactionManagerPtr()->checkOut(transId, objIdArray, id, errorMap);
        //调用Zoom命令使修改的实体位于屏幕中央,便于观察。
    if(acedCommand(RTSTR,"zoom",RTSTR,"e",0)!=RTNORM)
                return;
    // 修改调出实体的颜色。
    int colorIndex;
    acedGetInt("\n请输入新颜色: ", &colorIndex);
    AcDbObject* pObj;
    if (acdbOpenObject(pObj, transId, AcDb::kForRead) == Acad::eOk)
        // 获得长事务指针
        AcDbLongTransaction* pLongTrans = AcDbLongTransaction::cast(pObj);
        if (pLongTrans != NULL)
            // 获得长事务工作集迭代器。
            AcDbLongTransWorkSetIterator* pWorkSetIter;
            pLongTrans->newWorkSetIterator(pWorkSetIter);
            // 遍历工作集中的实体,并修改它们的颜色。
            for (pWorkSetIter->start(); !pWorkSetIter->done(); pWorkSetIter->step())
                acdbOpenAcDbEntity(pEntity, pWorkSetIter->objectId(), AcDb::kForWrite);
                pEntity->setColorIndex(colorIndex);
                pEntity->close();
            delete pWorkSetIter;
        pObj->close();
    // 暂停并观察修改后的结果。
    char str[132];
    acedGetString(0, "\n观察颜色。按enter键将修改后的实体写回原数据库。", str);
    // 将修改后的实体写回原数据库。
    acapLongTransactionManagerPtr()->checkIn(transId, errorMap);
    pDb->saveAs(fname);
    delete pDb;
    pDb = NULL;
    acad_free(fname);
GMT+8, 2026-11-6 00:16 , Processed in 0.421290 second(s), 38 queries , Gzip On.
