查看: 627|回复: 0
[求助]:XDRX_API 中 wordDraw()函数的疑问
发表于 2004-8-13 12:04:50 | 显示全部楼层 |阅读模式
参见了老大提供的程序
应用原话“
下面的代码是XDRX_API里面关于拖动选择集部分的虚函数worldDraw(..)的实现,里面拖动BLOCK,考虑了属性等
代码:
                virtual Adesk::Boolean  worldDraw(AcGiWorldDraw * wd)
                        wd->geometry().pushModelTransform(m_mat);
                        AcDbEntity* pE;
                        for (int i=0;iattributeIterator ();
                                                // if it allocated ok
                                                if (pAttributeIterator != NULL)
                                                        AcDbObjectId   ObjId;
                                                        AcDbAttribute *pAttribute = NULL;
                                                        // now loop through them
                                                        for (int count=0; !pAttributeIterator->done(); pAttributeIterator->step(), ++count)
        // get the object id of the attribute
        ObjId = pAttributeIterator->objectId();
        // open the object so we can draw it
        if (acdbOpenObject (pAttribute, ObjId, AcDb::kForRead) != Acad::eOk)
        continue;
        // now draw it
        wd->geometry().draw (pAttribute);
        // now close the attribute
        pAttribute->close();
                                                        // delete the iterator
                                                        delete pAttributeIterator;
                                                        // see if we have any attributes attached to this block
                                                        // if we have then to stop the attribute definitions being drawn
                                                        if (count)
        AcDbVoidPtrArray entitySet;
        // explode and get some temporary entities
        Acad::ErrorStatus es = pBlockref->explode (entitySet);
        // if it worked ok
        if (es == Acad::eOk)
        // loop round getting the intersection points
        for (long i=0l; igeometry().draw (pNewEnt);
        // delete the temporary entity
        delete pNewEnt;
                                                        // no attributes - just draw
                                                        else
        wd->geometry().draw(pE);
                                                // failed attribute iterator - just draw it
                                                else
                                        // not a block reference - just draw then
                                        else
                                        pE->close();
                        wd->geometry().popModelTransform();
                        return Adesk::kTrue;
看不懂这句                        AcDbEntity* pE;
for 循环中是不是打错什么了?
GMT+8, 2026-11-6 00:14 , Processed in 0.281047 second(s), 32 queries , Gzip On.
