查看: 786|回复: 2
[求助]:把3维线选择集高度转为0的矩阵,应怎么设
发表于 2004-8-18 14:05:20 | 显示全部楼层 |阅读模式
我有各顶点高度不同的3维线选择集想用acedXformSS转化
矩阵如下
1 0 0 0
0 1 0 0
0 0 0 0
0 0 0 1
这样设行吗
发表于 2004-8-18 16:56:13 | 显示全部楼层
肯定是这样啊。试试就知道了
 楼主| 发表于 2004-8-19 10:58:51 | 显示全部楼层
总是不行,程序在这,谁帮我看看
void tss()
        int i        ;                        // Row of ads_matrix
        ads_matrix xform;        // The transformation matrix
        ads_name ssGrp;                // The entities that make up transform SS
        int rc;                                // Return code
        ads_real sf;                // Scale Factor
        // Select the entities
        acedPrompt("\nSelect enties to scale (transfrom) ");
        rc = acedSSGet(NULL, NULL, NULL, NULL, ssGrp);
        if(rc != RTNORM)
                acutPrintf("\nEmpty or invalid selection set ");
                return;
        // Input the scale factor
        acedInitGet(RSG_NONULL + RSG_NONEG + RSG_NOZERO, NULL);
        //acedGetReal("\nTransformation Scale factor: ", &sf);
        // Initialize the matrix
        ident_init(xform);
      xform[2][2] = 0.0;
        // Apply the scaling factor
        // to the matrix
        //for(i = 0; i <= 3; i++)
        //        xform = sf;
        rc = acedXformSS(ssGrp, xform);
        if(rc != RTNORM)
                acutPrintf("\nFailed in transformation of selection set. ");
        acedSSFree(ssGrp);
void ident_init(ads_matrix id)
        int i, j;
        for(i=0; i<=3; i++)
                for (j=0; j<=3; j++)
                        id[j] = 0.0;
        for(i=0; i<=3; i++)
                id = 1.0;
GMT+8, 2026-11-6 02:41 , Processed in 0.441281 second(s), 36 queries , Gzip On.
