查看: 1264|回复: 6
[求助]:vb能否打开并显示dgn文件??
发表于 2004-8-19 19:05:33 | 显示全部楼层 |阅读模式
通过引用microstation的Objects Library可以在vb中打开dgn文件
能否接着在vb中将打开的dgn文件显示出来??
望高手解答,不胜感激!
发表于 2004-8-20 08:44:58 | 显示全部楼层
应该可以的!
你打算在VB哪里显示呢?
发表于 2004-8-20 09:39:12 | 显示全部楼层
先在模块中确认打开哪些dgn
Sub savefun()
Dim modalHandler As New SaveAsModalHand
AddModalDialogEventsHandler modalHandler
FileName1 = Dir(FilePathV8, vbNormal)
    Do While FileName1 <> ""
        CadInputQueue.SendCommand "DIALOG OPENFILE "
        FileName1 = Dir
    Loop
RemoveModalDialogEventsHandler modalHandler
End Sub
然后响应对话框事件
Implements IModalDialogEvents
Private Sub IModalDialogEvents_OnDialogClosed(ByVal DialogBoxName As String, ByVal DialogResult As MsdDialogBoxResult)
End Sub
Private Sub IModalDialogEvents_OnDialogOpened(ByVal DialogBoxName As String, DialogResult As MsdDialogBoxResult)
    If DialogBoxName = "Open" Then
        CadInputQueue.SendCommand "c,fileList_setFilterCmd *.dgn"
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setDirectoryCmd " & FilePathV8
        CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd " & FileName1
    '   Remove the following line to let the user close the dialog box.
        DialogResult = msdDialogBoxResultOK
    End If
End Sub
发表于 2004-8-20 13:35:49 | 显示全部楼层
cmx_stone:没看出哪一部分是用来显示DGN文件的内容的呀?!
你可能误解了1楼的意思了,不是用VB来列出DGN文件名而是想在VB的Form中显示DGN元素!!
发表于 2004-8-20 18:07:08 | 显示全部楼层
如果只是想在VB的FORM上显示DGN图形而不作编辑,那是可以实现的.因为用DGN的Element.GetPicture方法可以把Element的图像显示在VB的FORM上的Image控件上.你试试看吧.
 楼主| 发表于 2004-8-22 19:52:32 | 显示全部楼层
但是我查看ms v8的vba帮助,里面写的是
What is not in the Automation Object Model?
The Automation Object Model in MicroStation does not include the following capabilities and features:
Drawing design elements into an ActiveX control
Displaying a MicroStation view as an ActiveX control
Plotting, other than Windows printing
Creating MicroStation menu entries
Controlling visualization
而且在vb里面用对象浏览器查看的时候,ms的object libarery里面刚好没有image
该怎么办呢?
发表于 2005-6-16 09:46:44 | 显示全部楼层
不是说的很清楚了么??不行!!不过你可以用VB来封装倒十可以的!!
GMT+8, 2026-11-22 11:13 , Processed in 0.346991 second(s), 22 queries , Gzip On, File On.
