查看: 759|回复: 0
[日积月累]:关于PickfirstSelectionSet Bug的解决办法
发表于 2004-8-23 10:03:26 | 显示全部楼层 |阅读模式
也许并不是一个Bug,而是我们没发现罢了
  1. Sub Example_PickfirstSelectionSet()
  2.     ' This example lists all the objects in the pickfirst selection set.
  3.     ' Before running this example, create some objects in the active
  4.     ' drawing and select those objects. The objects currently selected
  5.     ' in the active drawing will be returned in the pickfirst selection set.
  6.
  7.     Dim pfSS As AcadSelectionSet
  8.     Dim ssobject As AcadEntity
  9.     Dim msg As String
  10.     msg = vbCrLf
  11.
  12.     Set pfSS = ThisDrawing.PickfirstSelectionSet
  13.     For Each ssobject In pfSS
  14.         msg = msg & vbCrLf & ssobject.ObjectName
  15.     Next ssobject
  16.     MsgBox "The Pickfirst selection set contains: " & msg
  17.
  18. End Sub
以上的例子在IDE窗口中运行没问题
调用-vbarun命令运行时不能正确运行
可以用下列方法j解决
定义Lisp函数:
  1. (defun tls-sub2cmd(filename subname cmdname)
  2. (eval
  3.   (list 'defun
  4.    (read (strcat "c:" cmdname))
  5.    nil
  6.    '(if (cadr(ssgetfirst)) (sssetfirst nil (ssget)))
  7.    (list 'vla-RunMacro
  8.          '(vlax-get-acad-object)
  9.           (strcat filename "!" subname)
  10.    )
  11.    '(sssetfirst nil nil)
  12.    '(princ)
  13.   )
  14. )
  15. (vlax-add-cmd cmdname (strcat "C:" cmdname))
  16. (princ)
  17. )
调用格式为:
(tls-sub2cmd "文件名" "宏名" "命令名")
GMT+8, 2026-11-3 10:49 , Processed in 0.488592 second(s), 32 queries , Gzip On.
