查看: 743|回复: 4
[求助] [求助]:如何获取层名
已领礼包: 2个
发表于 2004-8-26 11:15:53 | 显示全部楼层 |阅读模式
我想用LISP程序得到图形中所有的层名,请指教
发表于 2004-8-26 12:22:51 | 显示全部楼层
TBLSEARCH & TBLNEXT
发表于 2004-8-26 12:23:10 | 显示全部楼层
(defun c:test (/ d)
  (while
    (setq d (tblnext "layer" (null d)))
     (princ (cdr (assoc 2 d)))
     (princ "\n")
  (princ)
发表于 2004-8-29 17:04:04 | 显示全部楼层
这样更通用:
[php]
(defun tablelist (s / d r)
  (while
    (setq d (tblnext s (null d)))
    (setq r (cons (cdr (assoc 2 d)) r))
(defun c:test ()
  (tablelist "dimstyle")
[/php]
s 可以是LAYER,BLOCK,DIMSTYLE...
已领礼包: 2个
 楼主| 发表于 2004-8-30 12:58:43 | 显示全部楼层
我已试用上述程序,结果很好,谢谢各位的指教!!!
GMT+8, 2026-11-5 04:21 , Processed in 0.401961 second(s), 40 queries , Gzip On.
