查看: 1116|回复: 12
[文章]:浅议Excel及AUTOCAD 在国际工程计量中的应用
发表于 2005-9-29 21:29:48 | 显示全部楼层 |阅读模式
能在发一次吗?
发表于 2005-9-29 23:18:49 | 显示全部楼层
怎么下不了。File not found
You tried to access the address ftp://forum:*****@p4.xdcad.net/18681_excel%20%EF%BF%BD%EF%BF%BDautocad.rar, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Need help?
Open the Opera Help.
Go to Opera's on-line support desk.
发表于 2005-10-17 04:28:10 | 显示全部楼层
楼主那么多B了,还要啊,俺 好想哭啊,没法,谁让咱是穷人啊?!
发表于 2005-10-17 07:19:31 | 显示全部楼层
要钱就没意思了吧,你又不缺这点,是不是呀》
 楼主| 发表于 2005-10-18 07:53:59 | 显示全部楼层
偶不收爱心币了,这总可以了吧,^_^
发表于 2005-10-18 08:48:03 | 显示全部楼层
最初由 dxh 发布
[B]偶不收爱心币了,这总可以了吧,^_^ [/B]
可现在不能下了!!
发表于 2005-10-18 08:55:55 | 显示全部楼层
1楼得,下不了跟收不收爱心币好像是两码事啊!!
 楼主| 发表于 2005-11-8 09:58:12 | 显示全部楼层
我重新上传了,可以下了,没有收爱心币了,够意思吧,^_^
发表于 2005-11-8 11:00:19 | 显示全部楼层
要B才能下,何时才能凑够B
 楼主| 发表于 2005-11-8 15:36:15 | 显示全部楼层
只要你多发帖子就ok了。
发表于 2005-11-10 21:33:20 | 显示全部楼层
好东西,下来了,正在研究!
 楼主| 发表于 2005-11-28 08:39:05 | 显示全部楼层
希望大家有好东西,一起共享啊~~
发表于 2005-11-28 08:44:32 | 显示全部楼层
先下载了,有空再研究——不过,楼主为何不直接粘贴上来呢?让我们顶楼就可以了
GMT+8, 2026-8-30 18:09 , Processed in 0.642720 second(s), 53 queries , Gzip On.
