查看: 1534|回复: 2
[讨论]:AutoCAD2005中的 acad-push-dbmod
已领礼包: 593个
发表于 2004-9-3 12:21:57 | 显示全部楼层 |阅读模式
;|(只读)
类型:整数
不保存
用位码指示图形的修改状态。该值是下列位码值之和:
1 对象数据库被修改
4 数据库变量被修改
8 窗口被修改
16 视图被修改
32 字段被修改
保存图形时,DBMOD 的值被重置为 0。
;;Stores the current value of the DBMOD system variable
(acad-push-dbmod)
;;This function is used with acad-pop-dbmod to control the DBMOD system variable.
;;You can use this function to change a drawing without changing the DBMOD system
;;variable. The DBMOD system variable tracks changes to a drawing and triggers
;;save-drawing queries.
;;This function is implemented in acapp.arx, which is loaded by default.
;;This function pushes the current value of the DBMOD system variable onto
;;an internal stack. To use acad-push-dbmod and acad-pop-dbmod, precede operations
;;with acad-push-dbmod and then use acad-pop-dbmod to restore the original value of
;;the DBMOD system variable.
;;Return Values
;;Always returns T.
;;Examples
;;The following example shows how to store the modification status of a drawing,
;;change the status, and then restore the original status.
(acad-push-dbmod)
(setq new_line '((0 . "LINE") (100 . "AcDbEntity") (8 . "0")
             (100 . "AcDbLine") (10 1.0 2.0 0.0) (11 2.0 1.0 0.0)
             (210 0.0 0.0 1.0)))
(entmake new_line)            ; Set DBMOD to flag 1
(command "_color" "2")        ; Set DBMOD to flag 4
(command "_-vports" "_SI")    ; Set DBMOD to flag 8
(command "_vpoint" "0,0,1")   ; Set DBMOD to flag 16
(acad-pop-dbmod)
;;acad-pop-dbmod
;;Restores the value of the DBMOD system variable to the value that was
;;most recently stored with acad-push-dbmod
(acad-pop-dbmod)
;;This function is used with acad-push-dbmod to control the DBMOD system
;;triggers save-drawing queries.
;;This function pops the current value of the DBMOD system variable off
;;Return Values
;;Returns T if successful; otherwise, if the stack is empty, returns nil.
问题:4 数据库变量被修改都包括了哪些?
发表于 2004-9-3 13:40:22 | 显示全部楼层
儲存於:圖面--------資料庫變數 (ORTHOMODE)
儲存於:登錄--------非資料庫變數 (OSMODE)
已领礼包: 604个
发表于 2013-7-16 08:54:42 | 显示全部楼层
这个好象highflybir有所研究,实在是搞不懂,帮你顶一下。希望有看到高手们讨论:D
GMT+8, 2026-11-3 00:44 , Processed in 0.457797 second(s), 36 queries , Gzip On.
