楼主: ln2127105
[VBA程序]:毕业设计时候做的简单工具
 楼主| 发表于 2004-9-4 23:07:23 | 显示全部楼层
12
 楼主| 发表于 2004-9-4 23:09:31 | 显示全部楼层
13
 楼主| 发表于 2004-9-5 19:38:32 | 显示全部楼层
有人吗?有人来搞定吗??
发表于 2004-9-27 20:07:54 | 显示全部楼层
我来帮你搞定。
下面的是代码,但是我没搞懂你程序中的计算公式,不知你把y值缩小了几倍,最好把你的缩小倍数与我的缩小倍数n结合为一个,就OK了。还有,你光提供了一个弯矩最大值mm,应该还计算一个最小值,即负弯矩最大值。
另外,我在我的破电脑上运行时,如果不先把AUTOCAD2004打开,它就会报错,不知什么原因。
Public AcadApp As AcadApplication
Private Sub Command1_Click()
'打开AutoCAD
On Error Resume Next
Set AcadApp = GetObject(, "AutoCAD.Application.16")
If Err Then
   MsgBox Err.Description
   Err.Clear
   Set AcadApp = CreateObject("AutoCAD.Application.16")
   If Err Then
      Exit Sub
   End If
End If
AcadApp.Visible = True
AcadApp.WindowState = acMax
AcadApp.Documents.Add
Dim Va, u As Double
Dim Q1, Q2 As Double
Dim Ma, Mb, Mm As Double
Dim a As Double
Dim L As Double
Dim b As Integer
Dim c As Double
Dim n As Integer
Dim I As Integer
I = 2
Q1 = Val(Text3.Text)
Q2 = Val(Text4.Text)
a = Val(Text5.Text)
L = Val(Text6.Text)
Ma = Val(Text1.Text)
Mb = Val(Text2.Text)
Dim Lzx_Line As AcadLine
Dim Wjx_WPline As AcadLWPolyline
Dim WjPnt_Dou(0 To 2005) As Double
Dim Lqd(0 To 2) As Double
Dim Lzd(0 To 2) As Double
Dim TextObj As AcadText
Dim TextStr As String
Dim InsertPnt(0 To 2) As Double
Dim TextHight As Double
Lqd(0) = 0#: Lqd(1) = 0#: Lqd(2) = 0#
Lzd(0) = L: Lzd(1) = 0#: Lzd(2) = 0#
WjPnt_Dou(0) = 0
WjPnt_Dou(1) = 0
WjPnt_Dou(2004) = L
WjPnt_Dou(2005) = 0
If L <= 0 Or a > 0.5 Then
Picture1.Cls
Picture1.Line (0, 0)-(L, 0), QBColor(15)
MsgBox "数据输入错误!"
GoTo ends
End If
u = -1
Va = -(Ma - Mb) / (0.75 * L) + 0.5 * Q1 * L + (1 - a) * L * Q2 * 0.5
If Q1 = 0 And Q2 = 0 Then
b = 1
GoTo tu
End If
If Va - 0.5 * (2 * Q1 + Q2) * a * L <= 0 Then
b = 0
u = Va / (Q1 + 0.5 * Q2)
ElseIf Va - 0.5 * (2 * Q1 + Q2) * a * L > 0 And Va - 0.5 * (2 * Q1 + Q2) * a * L - (Q1 + Q2) * (L - a * L) <= 0 Then
u = (Va + 0.5 * a * L * Q2) / (Q1 + Q2)
b = 0
Else
u = (Va - 0.5 * Q2 * L + Q2 * a * L) / (Q1 + 0.5 * Q2)
b = 0
End If
tu:
If (Abs(Ma) > Abs(Mb) And b = 1) Or u < 0 Then
Mm = Ma
u = 0
ElseIf (Abs(Ma) < Abs(Mb) And b = 1) Or u > L Then
Mm = Mb
u = L
Else
Mm = -(Ma / 0.75 + Va * ux - 0.5 * (Q1 + Q2) * u ^ 2 + 0.5 * Q2 * a * L * (u - (1 / 3) * a * L))
End If
c = Abs(Mm) / 20
If c = 0 Then GoTo ends
'n是绘画y方向缩小倍数
n = Round(Abs(Mm) / L / 10) * 10
If n = 0 Then n = 1
Picture1.Scale (0, 50)-(L, -50)
Picture1.Cls
Set Lzx_Line = AcadApp.ActiveDocument.ModelSpace.AddLine(Lqd, Lzd)
Lzx_Line.Color = acGreen
Picture1.CurrentX = 0
Picture1.CurrentY = 0
'我把它设成宋体,如果你的windows字体
文件与我的不一样,请自己修改路径。
AcadApp.ActiveDocument.ActiveTextStyle.fontFile = "c:\windows\fonts\simsun.ttf"
TextHight = 0.15
Dim Ya, Ym, Yb As Double
For x = 0 To L Step L / 1000
    WjPnt_Dou(I) = x
    If x < a * L Then
       y = -((0.5 * Q1 * L * x - 0.5 * Q1 * x ^ 2) + (Ma - x * (Ma - Mb) / L) / 0.75 - Q2 * (x ^ 3) / (6 * a * L) + (0.5 * (L - a * L) * Q2 * x)) / c
       Picture1.Line -(x, y)
       WjPnt_Dou(I + 1) = y / n
       I = I + 2
       If x = 0 Then Ya = y / n
    ElseIf x <= L - a * L And x > a * L Then
      y = -((0.5 * Q1 * L * x - 0.5 * Q1 * x ^ 2) + (Ma - x * (Ma - Mb) / L) / 0.75 + 0.5 * Q2 * (L - a * L) * x - 0.5 * Q2 * a * L * (x - 2 * a * L / 3) - Q2 * (x - a * L) ^ 2 / 2) / c
      I = I + 2
   ElseIf x <= L And x > L - a * L Then
      y = -((0.5 * Q1 * L * x - 0.5 * Q1 * x ^ 2) + (Ma - x * (Ma - Mb) / L) / 0.75 - Q2 * ((L - x) ^ 3) / (6 * a * L) + (0.5 * (L - a * L) * Q2 * (L - x))) / c
      I = I + 2
      If x < L Then Yb = y / n
   End If
   If x = L Then Picture1.Line (L, y)-(L, 0)
   If (x - u) < L / 2000 Then Ym = y / n
Next x
TextStr = "横向比例:1:1000"
InsertPnt(0) = -2.5: InsertPnt(1) = 0.3: InsertPnt(2) = 0
Set TextObj = AcadApp.ActiveDocument.ModelSpace.AddText(TextStr, InsertPnt, TextHight)
TextStr = "纵向比例:1:" & Str(n * 1000)
InsertPnt(1) = 0
TextStr = "单位:KN , m"
InsertPnt(0) = -2.05: InsertPnt(1) = -0.3
Set Wjx_WPline = AcadApp.ActiveDocument.ModelSpace.AddLightWeightPolyline(WjPnt_Dou)
Wjx_WPline.Color = acRed
TextStr = "Ma=" & Str(Ma)
InsertPnt(0) = 0: InsertPnt(1) = Ya: InsertPnt(2) = 0
TextObj.Alignment = acAlignmentBottomRight
TextStr = "Mb=" & Str(Mb)
InsertPnt(0) = L: InsertPnt(1) = Yb
Lqd(0) = u: Lqd(1) = 0
Lzd(0) = u: Lzd(1) = Ym
Lzx_Line.Color = acCyan
TextStr = "x=" & Str(Round(u * 10000) / 10000) & " ,Mmax=" & Str(Int(Mm * 100) / 100)
InsertPnt(0) = u: InsertPnt(1) = Ym
ZoomExtents
Label8.Caption = Ma
Label10.Caption = Mb
Label12.Caption = Int(Mm * 100) / 100
Label13.Caption = Int(u * 100) / 100
ends:
End Sub
Private Sub Command2_Click()
End
End Sub
Private Sub Command3_Click()
Form2.Show
End Sub
发表于 2004-10-6 00:00:26 | 显示全部楼层
我想知道好不好做啊?
发表于 2004-10-11 00:31:15 | 显示全部楼层
估计下载完了别人早就把问题解决了,呵呵!
在线时间太短,下载时间间隔太长了!
 楼主| 发表于 2005-2-28 10:22:16 | 显示全部楼层
非常感谢19楼啊
发表于 2005-4-8 22:39:26 | 显示全部楼层
xzx
发表于 2005-4-11 16:56:23 | 显示全部楼层
赞..好好学习ing
发表于 2005-5-11 22:08:27 | 显示全部楼层
不错!真的很不错
 楼主| 发表于 2006-4-5 21:59:26 | 显示全部楼层
19楼的高人如何联系?
发表于 2006-4-24 13:10:03 | 显示全部楼层
好多啊
我下载的眼睛发晕啊
GMT+8, 2026-11-2 16:55 , Processed in 0.613155 second(s), 48 queries , Gzip On.
