查看: 793|回复: 2
[求助]:explode()怎么用?大家看看下面代码错在那里?
发表于 2004-9-13 21:28:21 | 显示全部楼层 |阅读模式
我想把block分解成一般的实体,可当对打散实体操作时总是出错不知为什么,请大家指教。
下面代码是其中的一部分,当调用函数extract()提取三维线的顶点时
es=p3DPL->openVertex(pVertex,ID,AcDb::kForRead,Adesk::kTrue);的返回值es总是Acad::eNullObjectId不知是什么原因?
void getBlockInfo()
        AcDbBlockTable *pBlkTbl;
        acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlkTbl, AcDb::kForRead);
        AcDbBlockTableRecord *pBlkTblRcd;
        pBlkTbl->getAt(ACDB_MODEL_SPACE, pBlkTblRcd, AcDb::kForRead);
        pBlkTbl->close();
        AcDbBlockTableRecordIterator *pBlkTblRcdItr;
        pBlkTblRcd->newIterator(pBlkTblRcdItr);
        AcDbEntity *pEnt;
        AcGePoint3dArray ptArray;
        int nNum,nColor=1,i;
        const char *objName;
        for (pBlkTblRcdItr->start(); !pBlkTblRcdItr->done();pBlkTblRcdItr->step())
                pBlkTblRcdItr->getEntity(pEnt, AcDb::kForRead);
                objName=pEnt->isA()->name();
                if(!stricmp(objName,"AcDbBlockReference"))
                        AcDbVoidPtrArray entitySet;
                        AcDbEntity       *pEntTmp;
                        pEnt->explode(entitySet);
                        //分解block(由三维线和一个圆组成)块
                        int n=entitySet.length();
                        for(i=0;i<n;i++)
                                pEntTmp=(AcDbEntity *)entitySet;
                                //提取三维线顶点坐标
                                if(extract(pEntTmp,ptArray))
                pEnt->close();
        pBlkTblRcd->close();
        delete pBlkTblRcdItr;
BOOL        extract(AcDbEntity *pEntity,AcGePoint3dArray &pointArray)
        if (pEntity==NULL)return false;
        AcGePoint3d pt;
        objName=pEntity->isA()->name();
        pointArray.setLogicalLength(0);
        if(!stricmp(objName,"AcDb3dPolyline"))
                AcDb3dPolylineVertex        *pVertex = NULL;
                AcDbObjectId                        ID;
                AcDb3dPolyline                        *p3DPL = (AcDb3dPolyline*)pEntity;
                AcDbObjectIterator *        pIter;
                Acad::ErrorStatus es ;
                pIter = p3DPL->vertexIterator();
                for (;!pIter->done();pIter->step())
                        ID=pIter->objectId();
                        if(Acad::eOk!=es)continue;
                        pt=pVertex->position();
                        pointArray.append(pt);
                        pVertex->close();
                delete pIter;
        else if(pEntity->isA()==AcDbCircle::desc())
        else
        return true;
发表于 2004-9-14 12:01:01 | 显示全部楼层
用[PHP]。。。[/PHP]来显示代码会增加可读性
改成
pBlkTblRcdItr->getEntity(pEnt, AcDb::kForWrite);
 楼主| 发表于 2004-9-14 15:50:35 | 显示全部楼层
对谢老兄指教,我改了之后还是不行,pBlkTblRcdItr->getEntity(pEnt, AcDb::kForWrite); 的返回值
为eLockViolation,不知是什么意思,请大哥帮忙!!
GMT+8, 2026-11-3 09:59 , Processed in 0.412034 second(s), 35 queries , Gzip On.
