查看: 782|回复: 4
[LISP程序]:请教斑竹和大虾
发表于 2004-9-15 10:09:27 | 显示全部楼层 |阅读模式
请教斑竹和各位大虾,LISP程序运行时提示:
***Internal  Error:VL namespace mismatch
是因为什么呀?怎么解决?亟盼回复!先谢谢了!
发表于 2004-9-15 11:30:57 | 显示全部楼层
Paste your codes please....
Reply From: Tanzillo, Tony
Date: Jan/16/03 - 15:32 (GMT)
    Re: Internal Error: VL Namespace Mismatch
It's generally caused by using data from one document in another.
It can occur by putting certain types of data on the 'blackboard'
(vl-bb-set/ref), and referencing it from the namespace of another document. Some types of LISP data are only valid in
the document
where they originated.
Another common cause is reactors.....
"CADMANCANDO" <cadmancando@yahoo.com> wrote in message news:f139777.-1@WebX.maYIadrTaRb...
> Using AutoCAD 2000. When I open a drawing I sometimes get the error "***Internal Error: VL Namespace Mismatch" Any
ideas on what this error refers to and/or why it's happening. Can't seem to find anything on the Knowledge Base. Thanks
 楼主| 发表于 2004-9-15 14:34:09 | 显示全部楼层
非常感谢您的回复,可是我不确定是哪个LISP程序引起的,我的这个程序使我们单位的老大哥以前写的一些程序,到cad2000/2002上就经常出现这个问题,但我曾经在程序里查找过没有发现用过vl-*的函数,不知道还有什么原因?
另外,不太明白这句话:It's generally caused by using data from one document in another.
麻烦您解释一下,好吗?
多谢!
发表于 2004-9-15 14:45:55 | 显示全部楼层
e.g You are in Drawing A, you run a lisp routine and try to get data from Drawing B...
 楼主| 发表于 2004-9-16 08:07:57 | 显示全部楼层
I see. thank you very much!
GMT+8, 2026-11-5 10:09 , Processed in 0.382732 second(s), 39 queries , Gzip On.
