查看: 825|回复: 3
[求助]:请问如何读取块中的图元
发表于 2004-9-16 09:22:19 | 显示全部楼层 |阅读模式
我想插入一块,然后将块中的图元的信息读出来,如一条直线的坐标?
发表于 2004-9-16 22:28:14 | 显示全部楼层
可以用矩阵试试
 楼主| 发表于 2004-9-18 13:26:02 | 显示全部楼层
请问如何编程?请不能说得更仔细点?
发表于 2004-9-19 13:11:39 | 显示全部楼层
Public Sub test111()
Dim pnt
Dim dot(2) As Double
Dim angle As Double
Dim oBlock As AcadBlock
Dim oUcs As AcadUCS
Set oBlock = ThisDrawing.Blocks.Add(dot, "*U")
Dim p1
p1 = ThisDrawing.Utility.PolarPoint(dot, Atn(1), 10)
oBlock.AddLine dot, p1
pnt = ThisDrawing.Utility.GetPoint
angle = ThisDrawing.Utility.GetAngle(pnt)
ThisDrawing.ModelSpace.InsertBlock pnt, oBlock.Name, 1, 1, 1, angle
Set oUcs = ThisDrawing.UserCoordinateSystems.Add(pnt, ThisDrawing.Utility.PolarPoint(pnt, angle, 1), ThisDrawing.Utility.PolarPoint(pnt, angle + Atn(1) * 2, 1), "Test")
Dim oEntitys(0) As AcadEntity
Set oEntitys(0) = oBlock(0)
a = ThisDrawing.CopyObjects(oEntitys, ThisDrawing.ModelSpace)
Set oEntitys(0) = a(0)
oEntitys(0).TransformBy oUcs.GetUCSMatrix
a = oEntitys(0).EndPoint
MsgBox a(0)
oUcs.Delete
End Sub
好像复杂了一点,其实可以用ThisDrawing.Utility.PolarPoint解决好像简单一些
GMT+8, 2026-11-3 15:04 , Processed in 0.468926 second(s), 38 queries , Gzip On.
