查看: 1590|回复: 7
[求助]:安装了CAD2002出了问题
发表于 2003-1-5 10:05:52 | 显示全部楼层 |阅读模式
卸了重装。
发表于 2003-1-5 10:11:15 | 显示全部楼层
我装了一年,还没见过这样的问题,照楼上的朋友的办法试试
 楼主| 发表于 2003-1-5 11:49:53 | 显示全部楼层
谢谢楼上各位的帮助,可我已经重装过2次了还是有问题虽然保存的文件还在,但总出这个窗口心烦的很。
发表于 2003-1-5 12:00:40 | 显示全部楼层
卸载后,清理注册表,用优化大师或兔子都可,然后再重装试试。或者FORMAT C盘再重装系统也可能行。
 楼主| 发表于 2003-1-5 13:14:21 | 显示全部楼层
我的硬盘上装了好多程序,格式化了重装不把我累死,我在别的地方也看到了ACDIM。ARX的BUG ,是不是2002和我电脑里某个硬件或是某个程序有冲突
Exceptionally alternative (2000)
Use the Dimstyle (Ddim) command and modify a dimension style. Pick the alternate units tab and turn on the Display alternate units toggle. Now create a new child style of that dimension for angular dimension. Pick the alternate units tab and turn off the Display alternate units toggle. Now pick any other tab of the dialog box, and AutoCAD falls over in a screaming heap. To be more precise, it reports
Exception in ACDIM.ARX ARX Command -- Unhandled Exception C0000005 (Access Violation Reading 0xffffffff at address 5F40277Eh
You must then use Task Manager to leave the locked-up AutoCAD session.
Workaround: Pick the OK button after you turn this toggle off. Then pick Modify and make any other changes in other tabs.
In the Text tab of the Dimstyle (nee Ddim) dialog box, a handy little [. . .] button takes you to the text style dialog box. If you choose a TrueType font in there, be very careful. If you move the top dialog box before applying the changes, or if you switch to another program and back to AutoCAD again, AutoCAD crashes, complaining of an exception in ACDIM.ARX, with this message:
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at 33018509h
No known workaround.
虽然我现在是在退出文件或CAD系统的时候出但提示是一样的
发表于 2003-1-5 14:00:05 | 显示全部楼层
安装了什么杀毒软件?
卸掉之后再装Acad2002试试。
发表于 2004-5-19 22:05:48 | 显示全部楼层
好像是与PKPM冲突
这个问题我也遇到了,应该是与PKPM冲突。换成2000的acdim.arx会损失功能吗?
发表于 2004-9-25 18:08:42 | 显示全部楼层
应该是与PKPM冲突??
我也是
GMT+8, 2026-10-21 01:18 , Processed in 0.447202 second(s), 43 queries , Gzip On.
