查看: 1030|回复: 11
[试用]:MSN7.0来了。。。(beta)
已领礼包: 7993个
发表于 2004-10-3 17:51:53 | 显示全部楼层 |阅读模式
http://download.pchome.net/php/t ... amp;svr=1&typ=0
*-*5
*-*5
*-*5
MSN Messenger 7.0在这次预览里面会被清晰的展现在你们面前。有了MSN Messenger 7.0,你现在可以从忙碌、离开、离线 状态下面登陆MSN Messenger。音乐软件3度也被集成在了MSN Messenger 7.0。MSN Messenger 7.0的界面更加简洁,人性化,而且展现更多的新特性!
MSN Messenger的主窗口被重新设计来显示你的显示图片并且可以卷动tabs。在主选项里面没有出现新的选项,但是你可以改变tab图标的位置了。当你的联系人从MSN Messenger 6或者更高版本的MSN Messenger登陆的时候,你会看到你的联系人的显示图片。传统的表情没有改变,他们依然不支持动态的GIF。
查看下面的截图了解更多的细节和大致的用户界面。MSN Messenger 7.0预计会在11月11号发布一个beta版本,附带一个会在2005年2月发布的“MSN Messenger Wave 10”。我们会继续关注MSN Messenger 7.0的最新动态,现在请你欣赏我们带来的截图。
已领礼包: 7993个
 楼主| 发表于 2004-10-3 17:54:50 | 显示全部楼层
安装界面
已领礼包: 7993个
 楼主| 发表于 2004-10-3 17:55:34 | 显示全部楼层
登录
已领礼包: 7993个
 楼主| 发表于 2004-10-3 17:56:17 | 显示全部楼层
动态表情,*-*7 *-*h *-*h
已领礼包: 7993个
 楼主| 发表于 2004-10-3 17:56:53 | 显示全部楼层
静态表情
已领礼包: 7993个
 楼主| 发表于 2004-10-3 17:58:35 | 显示全部楼层
发表于 2004-10-4 11:48:42 | 显示全部楼层
我从来不用,我只有QQ、UC、ICQ。
发表于 2004-10-4 12:57:31 | 显示全部楼层
我没有用过,有空试试。谢了!
已领礼包: 7993个
 楼主| 发表于 2004-10-5 09:27:21 | 显示全部楼层
不要用MSN messenger 7.0 BATE
As MSN Messenger 7 goes into private beta, Neowin has learned of several exploits resulting in the "winks" feature of MSN Messenger 7. A Neowin member wishing to remain anonymous has alerted us that users can generate their own flash movies and send them across MSN Messenger. As flash movies can open other things on the system such as Internet Explorer, this could be fatal. As MSN Messenger 7 is only beta and isn't available publically this isn't a major exploit but it does show that added features to a product like this makes it less secure and more open to attack/exploit.
MSN Messenger 7 is beta and is available in copies floating around the internet. We strongly advise members not to use the current beta until this flaw has been resolved. MSN Messenger 7 effectively opens your system up to allow a hacker to run numerous tasks on your machine.
口黑口黑。。。不好意思。。。
发表于 2004-10-5 09:46:20 | 显示全部楼层
从来不用
发表于 2004-10-5 12:23:49 | 显示全部楼层
够用就好
等熟了再用!!!
发表于 2004-10-5 14:46:13 | 显示全部楼层
不成熟的东东,还是先不要用的好。
GMT+8, 2026-11-3 04:03 , Processed in 0.742319 second(s), 55 queries , Gzip On.
