查看: 2439|回复: 27
[求助] [求助]:麻烦编写如下LISP ,急!
发表于 2004-10-16 21:12:00 | 显示全部楼层 |阅读模式
最好用LISP编写 能用于R14和2002
点击显示坡度和颇长 如图  只要显示在 命令行就可以 谢谢
发表于 2004-10-16 21:25:23 | 显示全部楼层
坡度带正负是什么意思?
 楼主| 发表于 2004-10-16 21:32:17 | 显示全部楼层
向上 为正坡 下坡为负坡 麻烦帮忙编写一个 LISP 谢谢
发表于 2004-10-16 21:57:10 | 显示全部楼层
坡度是用哪个来求的?
发表于 2004-10-16 22:06:13 | 显示全部楼层
[php]试试吧!没考虑水平线。
“向上 为正坡 下坡为负坡”,上下、正负如何确定?
;坡度坡长
(defun c:pdpc(/ s1 dist pd)
  (setq s1(entsel"\n\t选择LINE实体 : "))
  (if (= (ddxf 0 s1) "LINE")
    (progn
      (setq dist (abs (distance (ddxf 10 s1)(ddxf 11 s1)))
            pd (/ (- (cadr(ddxf 10 s1))(cadr(ddxf 11 s1)))
                  (- (car(ddxf 10 s1))(car(ddxf 11 s1)))
      (princ "\n\t坡长 = ")(princ dist)
      (princ "\n\t坡度 = 1:")(princ (abs ( / 1 pd)))(princ)
    (princ"\n\t无效,不是LINE实体!")
  (princ)
(defun dxf (code elist) (cdr (assoc code elist)))
(defun ddxf (code elist) (dxf code (entget (car elist))))
[/php]
 楼主| 发表于 2004-10-16 22:27:57 | 显示全部楼层
坡度就是 (Y2-Y1)/(X2-X1)
谢谢 XYP 如果是PLINE呢?
发表于 2004-10-17 01:14:07 | 显示全部楼层
晕啊.你的y2 y1,x2 x1又是什么?
线段的起点终点坐标的x y么?
 楼主| 发表于 2004-10-17 07:06:20 | 显示全部楼层
是啊  就是坐标啊
发表于 2004-10-17 09:10:41 | 显示全部楼层
[php]
;改进后只能识别单独的pline线(两个顶点):
;坡度坡长程序
(defun c:pdpc (/ s1 dist pd)
  (setq s1 (entsel "\n\t选择LINE或POLYLINE实体 : "))
  (setq st (ddxf 0 s1))
  (if (= st "LINE")
    (progn
      (setq dist (abs (distance (ddxf 10 s1) (ddxf 11 s1)))
            pd         (/ (- (cadr (ddxf 10 s1)) (cadr (ddxf 11 s1)))
                    (- (car (ddxf 10 s1)) (car (ddxf 11 s1)))
      (princ "\n\t坡长 = ")
      (princ dist)
      (princ (abs (/ 1 pd)))
      (princ)
  (if (or (= st "POLYLINE")(= st "LWPLINE"))
    (progn
      (endpt (car s1))
      (setq dist (abs (distance pts pte))
            pd         (/ (- (cadr pts) (cadr pte))
                    (- (car pts) (car pte))
      (princ "\n\t坡长 = ")
      (princ dist)
      (princ)
  (if (and (/= st "LINE") (/= st "POLYLINE")(/= st "LWPLINE"))
    (princ "\n\t无效选择,不是LINE、POLYLINE实体!")
  (princ)
;|取得曲线的起点,终点。 --陌生人.2004 支持arc,spline,pline,lwpline,el,line.|;
(defun endpt (e)
  (setq        eobj (vlax-ename->vla-object e)
        pts  (vlax-curve-getstartpoint eobj)
        pte  (vlax-curve-getendpoint eobj)
  (cons pts (list pte))
)[/php]
 楼主| 发表于 2004-10-17 10:49:26 | 显示全部楼层
多谢多写 能修改成识别 多个顶点的PLINE 或 直线吗?
发表于 2004-10-17 11:09:16 | 显示全部楼层
1. 直线肯定没有问题,因为没有多个顶点的直线!
2. 多个顶点的PLINE 会自动找到起点与终点,可以算出起点与终点连线的坡度和坡长。
发表于 2004-10-17 11:18:39 | 显示全部楼层
闹了半天,你这是断面啊
我一开始老看成是平面
 楼主| 发表于 2004-10-17 14:09:52 | 显示全部楼层
[QUOTE]最初由 xyp1964 发布
[B]1. 直线肯定没有问题,因为没有多个顶点的直线!
2. 多个顶点的PLINE 会自动找到起点与终点,可以算出起点与终点连线的坡度和坡长。 [/B][/QUOTE
不是 直线也可以连续的啊 但不是整体而已
PLINE 是要求显示被点击的段的起终点的坡度和长度 不是整段起终点的]
发表于 2004-10-17 14:47:21 | 显示全部楼层
直线只有起点与终点。
“PLINE 是要求显示被点击的段的起终点的坡度和长度 不是整段起终点的”的要求有点难!
再动动脑子!
已领礼包: 488个
发表于 2004-10-17 15:08:20 | 显示全部楼层
最初由 xyp1964 发布
[B]直线只有起点与终点。
再动动脑子! [/B]
是pl线,炸开,nentselp选到变成的直线,提取信息,再undo.
GMT+8, 2026-11-5 13:10 , Processed in 0.467927 second(s), 60 queries , Gzip On.
