查看: 1012|回复: 2
[LISP函数]:在vl里面如何用polar?
发表于 2004-10-18 18:45:20 | 显示全部楼层 |阅读模式
如果是vl里的变体alpt,如何利用polar函数呢?如下所示?可是不对呀,帮帮忙吧。
(setq al_pt(vlax-3d-point(polar (vlax-safearray->list al_pt) (* 1.5 pi) 70)))
发表于 2004-10-18 18:56:10 | 显示全部楼层
Re: [LISP函数]:在vl里面如何用polar?
最初由 urljit 发布
[B]如果是vl里的变体alpt,如何利用polar函数呢?如下所示?可是不对呀,帮帮忙吧。
(setq al_pt(vlax-3d-point(polar (vlax-safearray->list al_pt) (* 1.5 pi) 70))) [/B]
  1. (defun c:test (/ p p1 ac op)
  2.   (if (setq p (getpoint "\nFirst Point: "))
  3.     (progn
  4.       (setq p1 (vla-polarpoint
  5.                  (vla-get-utility
  6.                    (setq ac
  7.                           (vla-get-activedocument (vlax-get-acad-object))
  8.                    )
  9.                  )
  10.                  (setq op (vlax-3d-point p))
  11.                  0.
  12.                  10.
  13.                )
  14.       )
  15.       (vla-addline (vla-get-modelspace ac) op p1)
  16.     )
  17.   )
  18.   (princ)
  19. )
PolarPoint
Gets the point at a specified angle and distance from a given point.
Signature
RetVal = PolarPoint(Point, Angle, Distance)
Object
Utility
The object or objects this method applies to.
Point
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the start point.
Angle
Double; input-only
The angle in radians.
Distance
Double; input-only
The distance in current units.
RetVal
The 3D WCS coordinates at the specified angle and distance from a given point.
 楼主| 发表于 2004-10-18 20:02:56 | 显示全部楼层 |阅读模式
原来是val-polarpoint函数能解决问题呀!
free-lancer:你是怎样知道这个函数的呢?或者说我从哪里才能知道用哪个函数呢?给我个email吧。联系一下好吗?
GMT+8, 2026-11-5 09:22 , Processed in 0.369080 second(s), 38 queries , Gzip On.
