查看: 1005|回复: 3
[求助] [求助]:DCL对话框中如何调用幻灯库中的幻灯片文件
发表于 2004-11-2 16:32:58 | 显示全部楼层 |阅读模式
因DCL对话框需要调用幻灯片,这些幻灯片已被编译为幻灯库文件,请问在LISP中该如何调用幻灯库中的幻灯片?
发表于 2004-11-2 20:21:03 | 显示全部楼层
Creating Images
The calling sequence to create images for image tiles and image buttons is similar to the list-handling sequence. The start_image function begins the creation of an image, and end_image ends it. However, the type of image to draw is specified in separate function calls, instead of arguments:
vector_image
Draws a vector (a single, straight line) in the current image.
fill_image
Draws a filled rectangle in the current image.
slide_image
Draws an AutoCAD slide in the image.
Vectors and filled rectangles are useful for simple images, such as the color swatches (filled rectangles) that the AutoCAD Select Color dialog box uses to display the user's choice of color. For complicated images, slides are more convenient. However, displaying slides can be time-consuming. If you use slides, keep them simple.
Note  If you use slides with filled objects (such as wide polylines, solids, and 3D faces) in image tiles, the images will appear as outlines unless you make the slides from an image created with the SHADEMODE command.
The vector_image function requires that you specify absolute coordinates, while fill_image and slide_image require that you specify a starting coordinate along with a relative width and height. To do this correctly you must know the exact dimensions of the image tile or image button. Because these dimensions are usually assigned when the dialog box is laid out, the PDB feature provides functions that return the width and height of a particular tile. These dimension functions are dimx_tile and dimy_tile. You should call them before you begin creating an image. The origin of a tile, (0,0), is always the upper-left corner.
Colors can be specified as AutoCAD color numbers or as one of the logical color numbers shown in the following table. (The values and mnemonics are defined by the Autodesk Device Interface [ADI].) Dialog box color attribute
Color number
ADI mnemonic
Meaning
–2
BGLCOLOR
Current background of the AutoCAD graphics screen
–15
DBGLCOLOR
Current dialog box background color
–16
DFGLCOLOR
Current dialog box foreground color (for text)
–18
LINELCOLOR
Current dialog box line color
In the following example, "cur_color" is an image tile you want to fill entirely with a patch of red as follows:
(setq width (dimx_tile  "cur_color")
      height (dimy_tile "cur_color"))
(start_image "cur_color")
(fill_image 0 0 width height 1)   ;1 = AutoCAD red.
(end_image)
You can use the image-drawing functions in conjunction with each other. The following code fills an image and then draws a vertical stripe over it:
(setq width (dimx_tile "stripe")
      height (dimy_tile "stripe"))
(start_image "stripe")
(fill_image 0 0 width height 3)  ;3 = AutoCAD green.
(setq x (/ width 2))             ;Center the vector vertically.
(vector_image x 0 x height 4)    ;4 = AutoCAD cyan.
(end_image)
[B]The slides you display with slide_image can be standalone slide (SLD) files, or part of a slide library (SLB) file. If the slide is in an SLD file, you specify its name without the .sld extension (for example, "frntview"). If the slide is in a slide library, you specify the name of the library, followed by the name of the slide enclosed in parentheses. Note that the library and slide names are also specified without extensions—for example, "allviews(frntview)". The slide_image function searches for the slide or slide library file according to the current AutoCAD library search path. (See load in the AutoLISP Reference.) [/B]
In the following example, the slide is in a single file called topview.sld:
(setq x (dimx_tile "view")
      y (dimy_tile "view"))
(start_image "view")
( slide_image 0 0 x y "topview")
(end_image)
Vectors in slides are often drawn in white (color number 7), which is the default background color of an image. If your image tile is blank when you first display a slide, try changing its color attribute to graphics_background. (You can also change the background of the image by preceding the slide_image call with a fill_image call.)
 楼主| 发表于 2004-11-2 21:27:50 | 显示全部楼层
多谢aidraft  的指点:)
发表于 2004-11-3 07:20:45 | 显示全部楼层
呵!这样,谢了
GMT+8, 2026-11-5 10:18 , Processed in 0.369689 second(s), 38 queries , Gzip On.
