查看: 1538|回复: 1
[LISP程序]:如何获取cad运行期间所有lisp变量名称?
发表于 2002-3-12 12:10:34 | 显示全部楼层 |阅读模式
已领礼包: 145个
发表于 2002-3-12 12:24:49 | 显示全部楼层
Re: [LISP程序]:如何获取cad运行期间所有lisp变量名称?
最初由 fylinwater 发布
[B]如何获取cad运行期间所有lisp变量名称? [/B]
使用函数:
atoms-family
Returns a list of the currently defined symbols
(atoms-family format [symlist])
Arguments
format
An integer value of 0 or 1 that determines the format in which atoms-family returns the symbol names:
0  Return the symbol names as a list
1  Return the symbol names as a list of strings
symlist
A list of strings that specify the symbol names you want atoms-family to search for.
Return Values
A list of symbols. If you specify symlist, then atoms-family returns the specified symbols that are currently defined, and returns nil for those symbols that are not defined.
Examples
Command: (atoms-family 0)
(BNS_PRE_SEL FITSTR2LEN C:AI_SPHERE ALERT DEFUN C:BEXTEND REM_GROUP
B_RESTORE_SYSVARS BNS_CMD_EXIT LISPED FNSPLITL...
The following code verifies that the symbols CAR, CDR, and XYZ are defined, and returns the list as strings:
Command: (atoms-family 1 '("CAR" "CDR" "XYZ"))
("CAR" "CDR" nil)
The return value shows that the symbol XYZ is not defined.
GMT+8, 2026-11-3 07:33 , Processed in 0.407925 second(s), 34 queries , Gzip On.
