查看: 852|回复: 4
[求助]:那位老兄能帮忙提供一个.net2002的下载链接?
发表于 2004-11-5 09:25:24 | 显示全部楼层 |阅读模式
狗狗上面到处都找不到。谢谢了,急用啊
发表于 2004-11-22 07:14:36 | 显示全部楼层
ftp://ftp.hbu.net.cn/pub/%B1%E0% ... 20Stdio.NET/VS.NET/
这里有,用户名、密码都是hbu!
 楼主| 发表于 2005-12-27 13:27:13 | 显示全部楼层
非常感谢,但是还是下载不了  :(
发表于 2005-12-28 18:45:37 | 显示全部楼层
应该没问题呀!
Connecting to ftp.hbu.net.cn, Port 21 (#1)
Resolved host as: 202.206.1.8
Connected.  Waiting for response.
220-欢迎光临河北大学FTP服务器
服务由河北大学网络中心提供
现在时间28/12/05 18:38:43|
[声明]本站资源仅用于教学和研究
请务用本站资源进行非法活动。
校内匿名访问速度无限制
校外访问用户名hbu密码hbu
校外访问限制30用户速度限256K
如有疑问可以在燕赵BBS校
内资源版留言(bbs.hbu.cn)
目前服务器状态
你的IP是219.145.51.166,
————空间提示————
xx日删除剩余空间:10709.711 MBytes
TEMP除剩余空间:2819.02 MBytes
———传输状态提示———
上传速度:184 Bytes/s
出口速度4.545 MBytes/s
上传人数: 0
下载人数:3
220 河北大学FTP服务器
USER hbu
331 Password required for hbu.
PASS xxxxxx
230 User hbu logged in.
SYST
215 UNIX Type: L8
REST 100
350 Restarting at 100. Send STORE or RETRIEVE.
REST 0
350 Restarting at 0. Send STORE or RETRIEVE.
PWD
257 "/" is current directory.
TYPE A
200 Type set to A.
PORT 10,0,0,2,6,44
200 Port command successful.
LIST
150 Opening data connection for directory list.
226 Transfer ok.
Transfer done: 337 bytes in 0.010 secs (33.70 KB/s)
CWD pub
250 CWD command successful. "/pub" is current directory.
PWD
257 "/pub" is current directory.
TYPE A
200 Type set to A.
PORT 10,0,0,2,6,46
LIST
226 Transfer ok.
Transfer done: 1,066 bytes in 0.020 secs (53.30 KB/s)
CWD 编程开发
250 CWD command successful. "/pub/编程开发" is current directory.
PWD
257 "/pub/编程开发" is current directory.
TYPE A
200 Type set to A.
PORT 10,0,0,2,6,49
LIST
226 Transfer ok.
Transfer done: 2,349 bytes in 0.030 secs (78.30 KB/s)
CWD Visual Stdio.NET
250 CWD command successful. "/pub/编程开发/Visual Stdio.NET" is current directory.
PWD
257 "/pub/编程开发/Visual Stdio.NET" is current directory.
TYPE A
200 Type set to A.
PORT 10,0,0,2,6,51
LIST
226 Transfer ok.
Transfer done: 302 bytes in 0.030 secs (10.07 KB/s)
CWD VS.NET
250 CWD command successful. "/pub/编程开发/Visual Stdio.NET/VS.NET" is current directory.
PWD
257 "/pub/编程开发/Visual Stdio.NET/VS.NET" is current directory.
TYPE A
200 Type set to A.
PORT 10,0,0,2,6,53
LIST
226 Transfer ok.
Transfer done: 532 bytes in 0.060 secs (8.87 KB/s)
 楼主| 发表于 2005-12-29 02:45:02 | 显示全部楼层
我找到了新的下载地址
http://www.bbwk.com/down_view.asp?id=66  不过这个地方仅支持单线程的~~    要一个一个轮流下~~
GMT+8, 2026-11-6 00:12 , Processed in 0.400124 second(s), 40 queries , Gzip On.
