查看: 784|回复: 2
[求助] [求助]:如何遍历当前显示的图元(屏幕中)
发表于 2004-11-11 16:25:32 | 显示全部楼层 |阅读模式
如何遍历当前显示的图元(屏幕中),然后才可以分别编辑它的属性值。
(repeat (vla-get-count (model-space))
    (setq acadobj (vla-item (model-space) *index*))
    (if (vlax-write-enabled-p acadobj)
      (progn
(vla-put-LinetypeScale acadobj newvalue)
(setq *index1* (+ *index1* 1))
    (vlax-release-object acadobj)
    (setq *index* (+ *index* 1))
上面的程序遍历了model-space中的所有图元,不是我想要的,请高手赐教。
发表于 2004-11-11 17:38:14 | 显示全部楼层
下面程序返回屏幕上显示的图元数量,或许对你有用
[PHP]
(defun ent-number  (/ scrsize height width center llpt urpt enum ss)
  (setq scrsize (getvar "SCREENSIZE"))
  (setq height (getvar "VIEWSIZE")
        width  (* height (/ (car scrsize) (cadr scrsize)))
  (setq center (getvar "VIEWCTR"))
  (setq llpt (polar (polar center pi (/ width 2.0))
                    (* pi 1.5)
                    (/ height 2.0)
        urpt (polar (polar center 0 (/ width 2.0))
                    (* pi 0.5)
                    (/ height 2.0)
  (setq ss (ssget "w" llpt urpt))
  (if ss
    (setq enum (sslength ss))
    (setq enum 0)
;;;  (princ "\nNumber of entities found in current view : ")
;;;  (princ enum)
;;;  (princ)
[/PHP]
 楼主| 发表于 2004-11-12 08:14:54 | 显示全部楼层
感谢aidraft
GMT+8, 2026-11-5 13:10 , Processed in 0.394705 second(s), 35 queries , Gzip On.
