楼主: 关中到客
[文章]:世界十大最难看建筑
发表于 2004-12-21 13:32:41 | 显示全部楼层
很想看看他们长什么样,无法想象
发表于 2004-12-22 10:11:10 | 显示全部楼层
有世界十大最难看建筑的图片吗?
发表于 2005-1-11 11:04:55 | 显示全部楼层
有照片就更完美了
发表于 2005-1-15 23:35:28 | 显示全部楼层
青菜罗卜各有所爱,什么叫好看,什么又叫难看,这都是自己的评价,审美的角度不同,答案也就不同.~~~~~~~~~~~
发表于 2005-1-17 15:30:19 | 显示全部楼层
好坏其实听主观的,估计设计师并不觉得有什么大的问题,而且回造出来至少当初出钱的人是满意的,也许是天时、地利、人和有点不配合,老实说我可是没这个水平的,
发表于 2005-1-18 21:34:30 | 显示全部楼层
 1、英国伦敦千年穹Millennium Dome:烧钱无底洞
Did you know?
•        The Greenwich Dome is twice the size of the one in Atlanta Georgia.
•        If you turned The Dome upside down and put it under Niagra Falls, it would take 10 minutes to fill with water.
•        It is the largest fabric structure in the world containing one million square feet of fabric.
•        In volume terms it could hold as much water as 1,100 Olympic size swimming pools or 3.8 billion pints of beer!
•        The roof of The Dome covers 20 acres or 80,000 square metres and is so strong it could support the weight of a jumbo jet.
•        The Dome will contain the biggest amount of visitor attractions under one roof IN THE WORLD!
•        If you need parking for 18,000 double decker buses, no worries The Dome can take them!
•        Fancy a party? The Dome is 10 times the floor area of St. Paul's Cathedral; you really could invite all your friends.
•        There are 44 miles of steel forming the 'cobweb' that supports the roof.
•        The Dome will have 320 women's toilets, 65 disabled toilets, 120 men's cubicles plus 200 urinals!
•        There is a proposal for a chocolate factory to be housed inside The Dome. Fancy a Millenniyum-yum bar?
•        Each 'Zone' within the dome is about one acre in size.
•        You'll probably spend at least 5 hours at The Dome, probably 7 though if you want to take in all the zones.
发表于 2005-1-19 19:48:03 | 显示全部楼层
建出来就不错了
发表于 2005-1-27 20:04:24 | 显示全部楼层
Re: [文章]:世界十大最难看建筑
最初由 关中到客 发布
[B]最新一期的《福布斯》杂志评出了世界上十大最“难看”的建筑,英国伦敦的千年穹高居榜首,这似乎在人们的意料之中。世界著名设计师弗兰克·格利和贝聿铭等设计出的作品也难逃“厄运” 。
  1、英国伦敦千年穹:... [/B]
这个世纪最丑的建筑大概主要集中在中国的北京了。
大剧院一定能夺得桂冠,央视新楼也有不会名落孙山
发表于 2005-1-30 17:13:49 | 显示全部楼层
众口难调.
太过标新立意了,难免会如此.
发表于 2005-1-31 11:50:31 | 显示全部楼层
我觉得他们能让甲方出那么多钱并建成,已经不容易了!最差也许是说他的投入与回报不成正比吧!
GMT+8, 2026-11-23 21:22 , Processed in 0.282240 second(s), 25 queries , Gzip On, File On.
