查看: 859|回复: 3
[求助]:怎么对PDS底层数据库进行配置?
发表于 2004-12-17 15:37:26 | 显示全部楼层 |阅读模式
哪位大哥帮帮忙?
我准备学PDS,因为PDS必须对底层数据库进行配置才能使用,请问具体的底层数据库配置情况,能不能做个简单的介绍?万分感谢!
发表于 2004-12-17 16:53:27 | 显示全部楼层
Intergraph网站上有专门的说明,按照说明进行设置即可.曾经试着修改一些配置,但经常会出现不可解释的问题.
建议只对表空间的大小进行修改,其它尽可能不动。只有是ORACLE的高手才动(在高手协助下曾动过且成功,但自己还是不敢动,时间就是生命呀)
 楼主| 发表于 2004-12-17 19:10:58 | 显示全部楼层
等于没说,能不能简单介绍一下,或者提供详细网址位置。谢谢!
发表于 2004-12-31 18:48:12 | 显示全部楼层
本人安装了多个PDS 的oracle数据库,经验如下,只需要对表空间大小进行更改,别的没有必要动。可参照以下参数:
The procedure to finish the installation of the database is described below:
From the Start Menu, pick Oracle –OraHome92 > Configuration and Migration Tools -> Database Configuration Assistant.  In the Welcome Screen, click Next.
Step 1 - Choose Create Database and then Next.
Step 2 - (Database Templete) - Choose New Database, Next.
Step 3 - (Database Identification) - Enter the Gobal Database Name (name.domain - ex. pds.intergraph.com), click Next.
Step 4 - (Database Options) - Remove checks from Oracle Ultra Search, Example Schemas, Human Resources, Sales History.  Click Next.
Step 5 - (Database Connection Options) - Select Dedicated Server Mode and click Next.
Step 6 - (Initializaion Parameters) - accept the defaults for Archive, DB Sizing and File Locations.  Click Next.
Step 7 - (Database Storage) - Expand Tablespaces. For each of the tablespaces turn off Autoextend.
        a)   System.  On the Storage tab, select Managed in Dictionary, change Initial to 100KB, Next 100KB, Minimum Size 0KB, Increment size by 1%, Minimum number 1, Max number 121.
        b)   Users.  Change name to PDS, size to 300MB. Under Storage, select Managed in Dictionary, change Initial to 50KB, Next 50KB, Minimum Size 0KB, Increment Size By 1%, Minimum number 1, Max number 121.
        c)        Rollback_segs.  Create a rollback_segs tablespace size 50MB.  Under Storage, select Managed in Dictionary, change Initial to 512KB, Next 512KB, Minimum Size 0KB, Increment Size By 1%, Minimum number 2, Max number 4096.
        d)        Delete the INDX tablespace.
e)        Temporary.  Change name to Temp_Segs size 30MB. Under Storage, select Managed in Dictionary, change Initial to 100KB, Next 100KB, Minimum Size 0KB, Increment Size By 1%, Minimum number 1, Max number 121.
        f)        Create 20 rollback segments in the rollback_segs tablespace.  Click Next
Step 8 (Creation Options) - verify that Create Database is checked, click Finish.
Step 9 (Summary) - click OK to create the database. (Database will take approximately      10 to 20 minutes to complete.)
Step 10 (Finish) – change the default passwords and click
GMT+8, 2026-11-3 13:57 , Processed in 0.411973 second(s), 38 queries , Gzip On.
