查看: 1107|回复: 6
[求助] [求助]:有问题的lsp,问题是?
发表于 2005-1-5 13:04:08 | 显示全部楼层 |阅读模式
目的:转45
(defun c:45 (/ os obj pt)
  (setvar "CMDECHO" 0)
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq obj (getpoint "\n请选择对象:"))
  (setvar "osmode" 545)
  (setq pt (getpoint "\n请选择基点:"))
  (setvar "osmode" 0)
  (command "rotate" obj pt1 "45")
  (setvar "osmode" os)
  (princ)
发表于 2005-1-5 13:18:50 | 显示全部楼层
OBJ为一点,而在COMMAND中,要求OBJ为实体或选择集。
 楼主| 发表于 2005-1-5 13:24:47 | 显示全部楼层
我是菜鸟,能改个好的传上来对比对比????
发表于 2005-1-5 16:24:40 | 显示全部楼层
你将
这句改成:
(setq obj (entsel "\n  请选择对象 :"))
应该就可以了。
另最后一句个人认为用
(prin1) 比用 (princ)要好点。
 楼主| 发表于 2005-1-5 18:11:00 | 显示全部楼层
thanks for your answer.
and the 45 question in the picture?
i will try it .
已领礼包: 6530个
发表于 2005-1-5 21:39:30 | 显示全部楼层
问题出在“{command...}”一句,应该写成这样: (command "rotate" obj "" pt "45") ,少一个回车,pt写成pt1。
Obj使用getpoint选择当然不正确,但可以使用,这里相当于使用entsel拾取,但不能显示拾取框。
 楼主| 发表于 2005-1-6 19:02:41 | 显示全部楼层
谢过.
it should be that .
i try as 2nd floor friend but fail
i think you are right
还是显示:"未知命令“45”。按F1 查看帮助。"
怎么回事.程序改成下两都是这提示.
1:
(setvar "osmode" 0)
(setq obj (entsel "\n请选择对象:"))
(setvar "osmode" 0)
(command "rotate" obj "" pt1 "45" "")
(princ)
2:
(setvar "osmode" 0)
(setvar "osmode" 0)
(command "rotate" obj "" pt1 "45" )
(princ)
请各位指教指教
过五分钟后:抱歉抱歉,是我看错了没改好pt1成pt.
行了.
谢谢大家,对于黄金长老的帮忙更感谢......
GMT+8, 2026-11-6 21:08 , Processed in 0.534886 second(s), 44 queries , Gzip On.
