查看: 1270|回复: 2
[求助]:如何填充由一大一小两个同心圆组成的圆环?
发表于 2005-1-9 17:49:29 | 显示全部楼层 |阅读模式
如题,我想把圆环部分填充起来,但Arx里的AcDbHatch好像只能填充有相交的两实体组成的闭合区域,求该填充的实现方法.最好能贴个代码上来!
发表于 2005-1-9 23:12:30 | 显示全部楼层
源自帮助
The following example shows how to acquire an associative hatch entity on the WCS XY plane. The hatch boundary consists of an external rectangular loop with an internal circular hole. The hatch pattern is the ANSI31 predefined type with current AutoCAD default color. The newly created hatch is associative, in which you can change the source boundary geometry to update the hatch pattern.
Acad::ErrorStatus acqHatch2()
    AcDbHatch* pHatch = new AcDbHatch();
    // Set hatch plane
    AcGeVector3d normal(0.0, 0.0, 1.0);
    pHatch->setNormal(normal);
    pHatch->setElevation(0.0);
    // Set hatch pattern to ANSI31 predefined type
    pHatch->setHatchPattern(AcDbHatch::kPreDefined, "ANSI31");
    // Set Associativity
    pHatch->setAssociative(Adesk::kTrue);
    // Construct database AcDbLines
    AcGePoint2d vertexPts[4];
    AcDbObjectId lineId, cirId, hatchId;
    AcDbObjectIdArray dbObjIds;
    AcDbLine *line;
    vertexPts[0].set(2.0, 2.0, 0.0);
    vertexPts[1].set(8.0, 2.0, 0.0);
    vertexPts[2].set(8.0, 8.0, 0.0);
    vertexPts[3].set(2.0, 8.0, 0.0);
    for (int i = 0; i < 4; i++) {
        line =  new AcDbLine();
        line->setStartPoint(vertexPts)
        line->setEndPoint(vertexPts[(i == 3) ? 0 : i+1])
        line->postToDb(line, lineId);
        dbObjIds.append(lineId);
    // Append an external rectangular loop to hatch boundary
    pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds);
    // Create a AcDbCircle and post it to database
    AcGePoint2d cenPt(5.0, 5.0, 0.0);
    AcDbCircle *circle = new AcDbCircle();
    circle->setNormal(normal);
    circle->setCenter(cenPt);
    circle->setRadius(1.0);
    circle->postToDb(circle, cirId);
    dbObjIds.setLogicalLength(0);
    dbObjIds.append(cirId);
    // Append an internal loop (circle) to hatch boundary
    pHatch->appendLoop(AcDbHatch::kDefault, dbObjIds);
    // Elaborate hatch lines
    pHatch->evaluateHatch();
    // Get all associative source boundary object Ids for later use.
    pHatch->getAssocObjIds(dbObjIds);
    // Post hatch entity to database
    pHatch->postToDb(pHatch, hatchId);
    // Attach hatchId to all source boundary objects for notification.
    AcDbEntity *pEnt;
    int numObjs = dbObjIds.length();
    Acad::ErrorStatus es;
    for (i = 0; i < numObjs; i++) {
        es = acdbOpenAcDbEntity(pEnt, dbObjIds, AcDb::kForWrite);
        if (es == Acad::eOk) {
            pEnt->addPersistentReactor(hatchId);
            pEnt->close();
    return eOk;
 楼主| 发表于 2005-1-10 10:13:34 | 显示全部楼层
谢谢 binbin ,问题已解决
GMT+8, 2026-11-6 07:08 , Processed in 0.401581 second(s), 36 queries , Gzip On.
