查看: 520|回复: 1
[LISP程序]:告急,菜鸟急需标高加固定数字lisp小程序
发表于 2003-2-16 10:39:25 | 显示全部楼层 |阅读模式
告急,本人系菜鸟一个,急需标高加固定数字lisp小程序,望各位前辈援手,多谢,多谢!
发表于 2003-2-16 11:45:16 | 显示全部楼层
对标高文字的的要求,不大于200,小于-50,可在程序中自行修改。
要求标高文字在小数点后有二位或三位。
;;;标高差值统一加减   "上下各"
(defun c:bgs()
  (setq zzs 0)
  (setq bgd (getreal "\n标高差值:"))
  (if (or (/= bgd 0.0)(not bgd))
     (setq ee (ssget '((-4 . "<OR")(0 . "mtext")(0 . "text")(-4 .
"OR>"))))
     (setq ee nil)
  (if ee
    (progn
      (setq a1 0)
      (while (setq e1 (ssname ee a1))
        (setq a1 (1+ a1))
        (setq e (entget e1))
        (setq et (cdr (assoc '1 e)))
        (if (wcmatch et
          (progn
            (setq ez (read et))
            (if (< -50.00 ez 200.00)
              (progn
                (setq ez (+ ez bgd))
                (setq et (t-tr ez))
                (setq e (subst (cons 1 et)(assoc '1 e) e))
                (entmod e)(setq zzs (1+ zzs))
  (princ "\n共")(princ zzs)(princ "个标高修改.")
  (princ)
(defun t-tr( a / b )
  (setq b (rtos a 2 3))
  (cond
    ( (wcmatch b "*`.") (setq b (strcat b "000")) )
    ( (wcmatch b "*`.#") (setq b (strcat b "00")) )
    ( (wcmatch b "*`.##") (setq b (strcat b "0")) )
    ( (wcmatch b "*`.###") t )
    ( (not (wcmatch b "*`.*")) (setq b (strcat b ".000")) )
  (setq b b)
(princ "\nTYPE C:BGS To Run .")
(princ)
GMT+8, 2026-11-3 07:30 , Processed in 0.403881 second(s), 33 queries , Gzip On.
