查看: 801|回复: 4
[求助] [求助]:层的反选在lisp中如何写?
发表于 2005-2-23 13:25:53 | 显示全部楼层 |阅读模式
层的反选在lisp中如何写?
急!请指教
发表于 2005-2-23 14:00:07 | 显示全部楼层
[php]
;;;层的反选 <MJJ3468>
(defun test (la)
  (setq        s1 (ssget "x")
        s2 (ssget "x" (list (cons 8 la)))
  (if s2
    (progn
      (command "select" s1 "r" s2 "")
      (setq s3 (ssget "p"))
      s3
[/php]
 楼主| 发表于 2005-2-24 13:22:35 | 显示全部楼层 |阅读模式
谢谢白银长老,我先琢磨下,再来讨论.
发表于 2005-2-24 13:41:18 | 显示全部楼层
l1 l2 l3 层以外的实体
[php] (ssget "x" '((-4 . "<not") (8 . "l1,l2,l3") (-4 . "not>")))[/php]
发表于 2005-2-25 13:22:27 | 显示全部楼层
;;;层的反选
(defun bl (lay)
(setq ss (ssget "x" (list (cons 8 (strcat "~" lay)))))
GMT+8, 2026-11-6 02:37 , Processed in 0.482418 second(s), 42 queries , Gzip On.
