查看: 1513|回复: 3
[求助]:如何将DWG中的文字批量更改
发表于 2005-3-6 09:35:41 | 显示全部楼层 |阅读模式
由于要将DWG文件中N多的文字进行翻译, 想到了先将所有的文字全部导出到一文本文件中(已实现,代码如下)
//导出DWG文件中的文字串
void CTransTextDlg::OnBtExportText()
// TOD Add your control notification handler code here
AcDbDatabase* pDb;
AcDbBlockTable *pBlockTable;
pDb = acdbHostApplicationServices()->workingDatabase();
pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForRead);
pBlockTable->close();
AcDbBlockTableRecordIterator *pBlockIterator;
pBlockTableRecord->newIterator(pBlockIterator);
//打开文件用于输出
CString szFilter=_T("Data Files (*.dat;*.txt)|*.dat; *.txt|All Files (*.*)|*.*||");
CString szDefExt(_T(".DAT"));
CAcUiFileDialog dlg(FALSE, szDefExt, NULL,
OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT, szFilter);
dlg.DoModal();
CString strFileName;
strFileName = dlg.GetFileName();
ofstream out(strFileName);
if(!out)
MessageBox("指定导出文件无法打开!");
return;
//设置计数器
LONG lCounts = 0;
for (; !pBlockIterator->done(); pBlockIterator->step())
AcDbEntity *pEntity;
pBlockIterator->getEntity(pEntity, AcDb::kForRead);
const char *pCname = pEntity->isA()->name();
if(!strcmp(pCname, "AcDbText")) //是单行文字类
//获取文字内容
lCounts++;
const char *pText = ((AcDbText*)pEntity)->textString();
out<objectId()<<",\t"< }
else if(!strcmp(pCname, "AcDbMText")) //是多行文字类
lCounts++;
const char *pMText = ((AcDbMText*)pEntity)->contents();
out<objectId()<<",\t"< if(pMText)
pMText = NULL;
pEntity->close();
out.close();
delete pBlockIterator;
pBlockTableRecord->close();
翻译后欲重新导入原DWG文件中, 如下:
void CTransTextDlg::OnBtSubsTexts()
//打开文件用于输出
AcDbDatabase* pDb;
pDb->getBlockTable(pBlockTable, AcDb::kForRead);
CAcUiFileDialog dlg(TRUE, szDefExt, NULL,
dlg.DoModal();
ifstream in(strFileName);
if(!in)
MessageBox("指定导入文件无法打开!");
return;
//设置计数器
LONG lCounts = 0;
LONG lID;
Acad::ErrorStatus es;
es = pBlockIterator->getEntity(pEntity, AcDb::kForRead);
switch(es)
case Acad::eOk:
acutPrintf("Acad::eOk\n");
break;
case Acad::ePermanentlyErased:
acutPrintf("Acad::ePermanentlyErased\n");
break;
case Acad::eAtMaxReaders:
acutPrintf("Acad::eAtMaxReaders\n");
break;
case Acad::eWasOpenForNotify:
acutPrintf("Acad::eWasOpenForNotify\n");
break;
case Acad::eWasNotifying:
acutPrintf("Acad::eWasNotifying\n");
break;
case Acad::eWasOpenForUnd
acutPrintf("Acad::eWasOpenForUndo\n");
break;
case Acad::eWasOpenForWrite:
acutPrintf("Acad::eWasOpenForWrite\n");
break;
case Acad::eWasOpenForRead:
acutPrintf("Acad::eWasOpenForRead\n");
break;
default:
acutPrintf("Unknown error type.\n");
break;
//获取文字内容
acutPrintf("Step -- %ld\n", 4+lCounts);
lCounts++;
char inStr[256];
in>>lID>>inStr;
((AcDbText*)pEntity)->setTextString(inStr);
lCounts++;
char inStr[1024];
in>>lID>>inStr;
((AcDbMText*)pEntity)->setContents(inStr);
pEntity->close();
in.close();
可却有错! 请教了!!!
EMAIL: yuleyue@yahoo.com
发表于 2005-3-6 10:49:44 | 显示全部楼层
两种方式“
1,导出实体的handle,通过handle的对应关系进行导入。
2,在实体上添加信息,可以是xdata或者xrecord,然后根据添加的信息进行对应的导入导出。
 楼主| 发表于 2005-3-6 13:32:32 | 显示全部楼层
谢谢了,第一种方式中,是否如下:
void XXX
        char handleStr[20];                                                //句柄串
        char newText[1024];                                                //新字串
        ads_name entres;                                                //
    AcDbEntity* pEnt;                                                //
    AcDbObjectId objId;
        ifstream in("XXXX");                                        //包含编辑后内容的文本, 顺序与导出时一致
        while(!in.eof())
                in>>handleStr>>newText;                                //从打开的文本文件流中导入上述二字串
                acdbHandEnt(handleStr, entres);                //找到实体名
                acdbGetObjectId(objId, entres);                //根据实体名找到ID
                acdbOpenAcDbEntity(pEnt, objId, Acad::eForWrite);                //打开ID所对应的实体用于写操作
                const char *pCname = pEnt->isA()->name();                //实体所属类名
                if(!strcmp(pCname, "AcDbText"))        //单行文字类
                        ((AcDbText*)pEnt)->setTextString(newText);        //替换原有字串
                if(!strcmp(pCname, "AcDbMText"))        //多行文字类
                        ((AcDbMText*)pEnt)->setContents(newText);        //替换原有字串
                pEnt->close();
        in.close();
发表于 2005-3-7 09:23:58 | 显示全部楼层
还有一种方法,用长事务类可以实现,并且留下bak文件。
GMT+8, 2026-11-22 09:10 , Processed in 0.631558 second(s), 17 queries , Gzip On, File On.
