查看: 848|回复: 9
[公告]:Autodesk公司推出官方的解决AutoCAD2005启动慢的补丁!
发表于 2005-3-6 23:26:08 | 显示全部楼层 |阅读模式
SIZE=3]14[/SIZE] 终于用AutoCAD2005享受到了R14的打开速度[/COLOR]
http://usa.autodesk.com/adsk/ser ... &linkID=2475161
从文字看将其责任归咎于大字符集,也就是说是由于汉字这样的字体造成的。
Slow Launch with a Large Number of Fonts
This update corrects a problem that significantly slows startup and operation of AutoCAD® 2005-based products that have a large number of fonts installed. The acdb16.dll file is replaced.
Description of Problem
Activities such as starting the product and creating multiline text are extremely slow on operating systems with a large number of TrueType fonts installed.
Affected Products
Installation Instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
Close all software applications.
Find the Autodesk Shared folder, usually c:\Program Files\Common Files\Autodesk Shared.
In this folder, rename the acdb16.dll file: Right-click the file name, click Rename on the shortcut menu, and enter a new name such as acdb16.bak.
Download the new acdb16.dll file and copy it to the same Autodesk Shared folder.
Restart the application.
发表于 2005-3-7 08:40:54 | 显示全部楼层
呵呵,早有版主完成了所有的解决方法了。但速度提升不是很明显
发表于 2005-3-7 08:50:38 | 显示全部楼层
早就知道了
发表于 2005-3-7 22:30:30 | 显示全部楼层
好象作用不大的
 楼主| 发表于 2005-3-7 22:39:23 | 显示全部楼层
最初由 意外得手 发布
[B]好象作用不大的 [/B]
注意看英文说明,要退出AutoCAD时安装;安装好后重登入一下。
我安装了这个补丁后,速度明显加快,进入AutoCAD2005几乎没有什么停顿就好了,与以前完全不一样。
发表于 2005-3-8 14:21:30 | 显示全部楼层
我下载了,但无法安装,是个acdb16.dll文件,是直接复制吗?复制到哪?或其他?
发表于 2005-3-8 15:32:25 | 显示全部楼层
安装后,好象是快了点
发表于 2005-3-8 18:23:10 | 显示全部楼层
覆盖C:\Program Files\Common Files\Autodesk Shared下同名文件,最好先备份好原文件
发表于 2005-3-8 20:58:00 | 显示全部楼层
不错,安装后,速度提高很明显
 楼主| 发表于 2005-3-9 08:05:30 | 显示全部楼层
最初由 wtx1976 发布
[B]我下载了,但无法安装,是个acdb16.dll文件,是直接复制吗?复制到哪?或其他? [/B]
看一楼。
GMT+8, 2026-10-23 03:05 , Processed in 0.445092 second(s), 49 queries , Gzip On.
