查看: 1027|回复: 3
[编程申请]:将所有含88]88+88]88的字符串变成红色
发表于 2005-3-8 12:43:06 | 显示全部楼层 |阅读模式
已领礼包: 12482个
发表于 2005-3-8 19:57:53 | 显示全部楼层
[php]
(DEFUN C:CH-RED ()
(PRINC "\nPlease Select Text(s) 请选择文字 :")
(SETQ SS (SSGET "X" '((0 . "TEXT")))
       I 0)
(REPEAT (SSLENGTH SS)
  (SETQ ENT (SSNAME SS I) I (1+ I)
        STR (CDR (ASSOC 1 (ENTGET ENT))))
  (IF (WCMATCH STR "*88]88*") (COMMAND "CHANGE" ENT "" "P" "C" "1" ""))
(PRINC)
[/php]
发表于 2005-3-8 20:16:47 | 显示全部楼层
(defun c:ch-red()
(setq ss (ssget '((0 . "TEXT")(1 . "*88]88*"))))
(command "chprop" ss "" "c" 1 "")
(prin1)
 楼主| 发表于 2005-3-9 12:23:48 | 显示全部楼层
以上两位程序完全都可用,谢谢!
GMT+8, 2026-11-3 01:27 , Processed in 0.547731 second(s), 37 queries , Gzip On.
