查看: 1627|回复: 13
[下载]:地暖安装图集.zip
发表于 2005-3-9 14:23:13 | 显示全部楼层 |阅读模式
*-*b
发表于 2005-3-11 08:57:27 | 显示全部楼层
刚干完一个地热的活,看看有没有相关的内容!!
发表于 2005-3-23 12:08:50 | 显示全部楼层
正好需要参考一下
发表于 2005-3-25 10:39:51 | 显示全部楼层
正在帮朋友作一个,下了学习一下,可能有价值,先谢了。
发表于 2005-3-25 11:37:46 | 显示全部楼层
怎么不能下载?
出现这种情况:
Fri Mar 25 11:27:49 2005 正在连接 p4.xdcad.net:21
Fri Mar 25 11:27:49 2005 正在连接 p4.xdcad.net [IP=61.152.251.210:21]
Fri Mar 25 11:27:50 2005 Socket已连接 ,等待欢迎信息
Fri Mar 25 11:28:03 2005 有错误发生!
Fri Mar 25 11:28:03 2005 等待 5秒后重试
Fri Mar 25 11:28:08 2005 正在连接 p4.xdcad.net [IP=61.152.251.210:21]
Fri Mar 25 11:28:08 2005 Socket已连接 ,等待欢迎信息
Fri Mar 25 11:28:08 2005 220 Serv-U FTP Server v6.0 for WinSock ready...
Fri Mar 25 11:28:08 2005 USER forum
Fri Mar 25 11:28:12 2005 331 User name okay, need password.
Fri Mar 25 11:28:12 2005 PASS ********
Fri Mar 25 11:28:12 2005 230 User logged in, proceed.
Fri Mar 25 11:28:12 2005 成功登录
Fri Mar 25 11:28:12 2005 REST 100
Fri Mar 25 11:28:15 2005 350 Restarting at 100. Send STORE or RETRIEVE.
Fri Mar 25 11:28:15 2005 该站点支持断点续传.
Fri Mar 25 11:28:15 2005 REST 0
Fri Mar 25 11:28:15 2005 350 Restarting at 0. Send STORE or RETRIEVE.
Fri Mar 25 11:28:15 2005 TYPE A
Fri Mar 25 11:28:15 2005 200 Type set to A.
Fri Mar 25 11:28:15 2005 PORT 61,54,26,179,5,103
Fri Mar 25 11:28:15 2005 200 PORT Command successful.
Fri Mar 25 11:28:15 2005 LIST /320313_地暖安装图集.zip
Fri Mar 25 11:28:16 2005 150 Opening ASCII mode data connection for /bin/ls.
Fri Mar 25 11:28:37 2005 426 Data connection closed, transfer aborted.
Fri Mar 25 11:28:37 2005 有错误发生!
Fri Mar 25 11:28:37 2005 等待 5秒后重试
Fri Mar 25 11:28:42 2005 正在连接 p4.xdcad.net [IP=61.152.251.210:21]
Fri Mar 25 11:28:42 2005 Socket已连接 ,等待欢迎信息
Fri Mar 25 11:28:42 2005 220 Serv-U FTP Server v6.0 for WinSock ready...
Fri Mar 25 11:28:42 2005 USER forum
Fri Mar 25 11:28:42 2005 331 User name okay, need password.
Fri Mar 25 11:28:43 2005 PASS ********
Fri Mar 25 11:28:43 2005 230 User logged in, proceed.
Fri Mar 25 11:28:43 2005 成功登录
Fri Mar 25 11:28:43 2005 TYPE A
Fri Mar 25 11:28:43 2005 200 Type set to A.
Fri Mar 25 11:28:43 2005 PORT 61,54,26,179,5,108
Fri Mar 25 11:28:45 2005 200 PORT Command successful.
Fri Mar 25 11:28:45 2005 LIST /320313_地暖安装图集.zip
Fri Mar 25 11:28:45 2005 150 Opening ASCII mode data connection for /bin/ls.
Fri Mar 25 11:29:06 2005 426 Data connection closed, transfer aborted.
Fri Mar 25 11:29:06 2005 有错误发生!
请高手解决。
发表于 2005-3-30 10:35:21 | 显示全部楼层
看看先
发表于 2005-4-5 11:23:30 | 显示全部楼层
谁解决一下五楼的问题呀?下载地址有问题吗?
发表于 2005-4-29 11:12:47 | 显示全部楼层
有问题?
发表于 2005-4-30 10:26:36 | 显示全部楼层
我刚好需要啊 正在搞设计啊
发表于 2005-5-4 17:12:47 | 显示全部楼层
可以哈,一定好好学学习啊
发表于 2005-5-13 21:28:35 | 显示全部楼层
怎样才能得到积分 不能下呀
发表于 2005-5-13 23:06:01 | 显示全部楼层
我好好想要啊
发表于 2005-5-15 16:33:39 | 显示全部楼层
唉,没积分, 但我好想看看
发表于 2005-5-17 17:07:39 | 显示全部楼层
可以下载的
GMT+8, 2026-11-22 11:06 , Processed in 0.396469 second(s), 36 queries , Gzip On, File On.
