查看: 714|回复: 0
[文章]:key-----
发表于 2005-3-14 17:32:16 | 显示全部楼层 |阅读模式
In moving items around the screen (especially text) I find I am turning the snaps off a lot for which I use the "SO" keybord shortcut - two letters that are far apart on the keyboard. I would like to get it down to one key like F6 or just "S", but when I edit the text file ("SO" snapcode:"snaps off") by substituting the "SO" with "F6" or "S" it doesn't work. In fact the only thing that seems work so far is "SO".
GMT+8, 2026-11-3 14:04 , Processed in 0.548715 second(s), 31 queries , Gzip On.
