查看: 957|回复: 3
[ARX函数]:vla方法的一个小例子
发表于 2005-3-15 01:09:46 | 显示全部楼层 |阅读模式
CAD帮助里的vla选择集获取方法的解释
object.Select Mode[, Point1][, Point2][, FilterType][, FilterData]
Object
SelectionSet
The object or objects this method applies to.
Mode
AcSelect enum; input-only
acSelectionSetWindow
acSelectionSetCrossing
acSelectionSetPrevious
acSelectionSetLast
acSelectionSetAll
Point1
Variant (array of doubles); input-only; optional
The 3D WCS coordinates, or array of coordinates, specifying Point1. See the mode definitions for the proper use of Point1.
Point2
Variant (three-element array of doubles); input-only; optional
The 3D WCS coordinates specifying Point2. See the mode definitions for the proper use of Point2.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
我写了个获取选择集的代码
;;vla方法建立对象选择集vlass
(setq doc           (vla-get-ActiveDocument (vlax-get-acad-object))
           *mspace* (vla-get-ModelSpace doc)
          sss(vla-get-SelectionSets doc)
         vlass(vla-add sss "vlaset"))
(setq pt1(vlax-3d-point (getpoint))
      pt2(vlax-3d-point (getpoint)))
(setq gpcode (vlax-make-safearray vlax-vbInteger '(0 . 1));过滤表的组码
      gpdata (vlax-make-safearray vlax-vbVariant  '(0 . 1)));过滤表的值
(vlax-safearray-fill gpcode '(0 2))
(vlax-safearray-fill gpdata  (list (vlax-make-variant "INSERT" vlax-vbString) (vlax-make-variant "TRIAN" vlax-vbString)))
(vla-Clear vlass);清空vlass
(vla-Select vlass acSelectionSetCrossing pt1 pt2 gpc1 gpd1);向vlass选择集中添加对象
;验证选择结果
(vlax-for x vlass
  (setq en(vla-get-name x))
  (princ "\n")
  (princ en)
发表于 2005-3-15 23:29:22 | 显示全部楼层
强,顶上去
发表于 2005-3-16 08:01:48 | 显示全部楼层
用vla的SelectionSet系列来选物体,缺点是不像ssget那样可自由决定选择方式
发表于 2005-9-3 17:30:14 | 显示全部楼层
如何用vla获取系统变量值(如"extmin"等)
GMT+8, 2026-11-6 14:29 , Processed in 0.468445 second(s), 38 queries , Gzip On.
