查看: 856|回复: 2
[求助]:我的代码问题出在哪里?
发表于 2005-3-15 20:56:44 | 显示全部楼层 |阅读模式
本VB程序要实现的功能是在AUTOCAD中选取的点上创建一文字实体,可是Cad怎么也不会停下来等待输入点,请高手指点下毛病出在哪儿,谢谢!
Private Sub Command1_Click()
writ
End Sub
Sub writ()
    Dim acad  As Object
    On Error Resume Next
    Set acad = GetObject(, "AutoCAD.Application")
    If Err <> 0 Then
        Set acad = CreateObject("AutoCAD.Application")
         MsgBox "没有打开CAD图文件!"
         acad.Visible = True
         acad.getfoucs
      '   Exit Sub
    End If
    Set doc = acad.ActiveDocument
    Set mspace = doc.ModelSpace
    'Dim textobj As AcadText  r2000+
    Dim textobj As Object   'r14
    Dim height As Double
    Dim Insertpoint(0 To 2) As Double
    Dim testString As String
    Dim i As Integer
    Dim j As Integer
    Dim pt As Double
    Dim pnt As Variant
    AppActivate acad.Caption, False
    pnt = acad.GetPoint(, "选择插入点: ")
     testString = "测试文字"
     height = 300
     Set textobj = mspace.AddText(testString, pnt, height)
End Sub
发表于 2005-3-16 20:26:19 | 显示全部楼层
我用的cad2005,修改了版本号.
writ
End Sub
Sub writ()
Dim acad As Object
Set acad = GetObject(, "AutoCAD.Application.16")
If Err <> 0 Then
    Set acad = CreateObject("AutoCAD.Application.16")
    acad.Visible = True
    acad.getfoucs
    ' Exit Sub
End If
Dim Height As Double
Dim i As Integer
Dim j As Integer
Dim pt As Double
Dim pnt As Variant
pnt = acad.ActiveDocument.utility.GetPoint(, "选择插入点: ")                   '''//////关键在这里
testString = "测试文字"
Height = 300
Set textobj = mspace.AddText(testString, pnt, Height)
End Sub
 楼主| 发表于 2005-3-23 07:25:56 | 显示全部楼层
谢谢老大的帮助,我马上测试!
今天忙了一天,晚上才有空重试程序,已经完成,再次感谢nt的指点!
GMT+8, 2026-11-22 11:33 , Processed in 0.187994 second(s), 14 queries , Gzip On, File On.
